Results 1 to 14 of 14
Thread: Sand or dead algae?
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Question Sand or dead algae?
    I'm in the middle of my SLAM and pool is crystal clear today and I can finally see the deep end clearly. I have what looks like a LOT of sand or dead algae in the deep end. How can I tell the difference?
    Lynzizzle
    IG, 25k gal (est.), concrete free form, Hayward S-244T 300lb sand filter,
    well water, Pump: AO Smith 3/4 hp, VSpd: Unknown, Pool Age: Unknown
    Welcome to our OOL. Notice there's no "P" in it?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Sand or dead algae?
    Sand will be gritty. If you have a vacuum that has a bag filter on it, you could vacuum it up to see.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    I don't I vacuum to waste (for now anyway)
    Lynzizzle
    30,432
    Brush it up. Sand will settle quickly back to the floor......algae will brush up into a cloud and seem to go away for a short while.
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    I'm pretty sure it's sand. That's an AWFUL lot of dead algae in my pool.
    Lynzizzle
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Sand EVERYWHERE!
    Merged by Divin Dave
    So I'm pretty sure my filter is spitting all of it's sand into my pool. I have an insane amount of what looks to be dead algae on my pool floor. I just started the pool up Friday and pool was perfectly clear yesterday, allowing me to see the deep end clearly. I do still have some leaves and stuff in the deep end that need sucked up, however, this sandy/algaey substance in the bottom is making it next to nearly impossible.
    Is this dead algae or in fact sand? And can I vacuum up the substance to deposit back into my filter rather than vacuuming to waste?
    The filter lateral, sand and all o-rings/gaskets were replaced by a pool company last season at the beginning of the season. Could it seriously be that the lateral is cracked AGAIN?
    I started the pool up myself this year due to a HORRIBLE experience with said pool company and being stood up by a second pool company (the company who closed us down for the season). Did I possibly do this to myself?! I cant find the receipt for the repair work from last year to see if the work was warranted or not, but in all honesty, not sure I want those people back anyway.
    Someone please help!
    Lynzizzle
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Sand EVERYWHERE!
    You need to get in the pool and try so pick some up. Dead algae feels squishy. Sand feels, well, sandy. You'll know.
    Answer that question, and also, please post a full set of test results. That will also help us determine if there's something living in your pool and why.
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    5/19 Results
    FC: 8.5
    CC: 0
    TC: 8.5
    CYA: 0 - filled another sock tonight to bring it up
    PH: 7.5 - right on the money!! ��
    Lynzizzle
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    My money is on dead algae. Can you scoop some in a net? If it is sand then you have a bigger problem with your filter and some broken parts inside.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    it makes logical sense that its dead algae on the bottom. After all, you are in the middle of a slam and dead algae looks like sand.
    If you want to verify if sand is coming from your returns, use a rubber band and a nylon sock or some other material and rubber band the nylon sock to one of your returns.
    If sand is spitting back in the pool, the nylon will catch it.
    Divin Dave,
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    ^this is what the inside of my filter looks like
    ^sand?
    Lynzizzle
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Lynzizzle
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Ok took both MPV and filter apart and nothing both look perfectly fine ::sigh::
    Lynzizzle
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Now I have sand in my MPV
    Lynzizzle
