Thread: Draining a pool
    Draining a pool
    I have an in-ground pool and live in Arizona. The pool has a a paper filter and is approximately 10,000 gallons. My pool pump went out on me and it was a couple weeks before someone finally came out to repair it. Though I kept cholrine in it and tried to maintain the algea it has been over taken. I am now at the point of draining the pool (after several attempts to vaccum, add checmicals and change the filter).
    My questions are these:
    1. How long can I safely leave my pool empty without causing damage to the plaster?
    2. What can I do to clean the plaster beofre I fill the pool?
    3. I have a few broken tiles. What do you reccomend to reattach those tiles?
    4. Is there anything else you might recommend that I do while the pool is empty or before refilling?
    Thanks for your help!
    Re: Draining a pool
    Nothing you describe suggests any need to drain the pool. You will want to lower the water level below the tiles when working on the tiles, but no need for a complete drain. Draining for a while is usually fine, but if your water table is high there can be extreme damage to the pool. It is best not to take that risk unless there is some stronger reason to drain.
    There is a good write up on fighting algae here.
    I can't help you with the tile work. Hopefully someone will be along soon who knows more about that.
    Jun 2008
    Tucson area, AZ
    Re: Draining a pool
    If you use algaecide, use a polyquat 60 algaecide, ie Leslie's algae control. It's expensive, approx. $20.00 qt., but it doesn't contain copper, which will stain, and, unlike the cheaper stuff, it doesn't foam, and it works.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
