Thread: Raypak RP2100 Cycling continuously: operational, PRS, SPK, operational......
    May 2015
    albuquerque
    4
    I have a Raypak heating problem. I turn the heater on and the unit goes into CFH, I hear the ignition, hear the flame for 30 seconds or so then a super quick PRS, SPK, and the process starts all over. The interval is not consistent, often times the operation does not last 30 seconds.
    i did however pull the leads to the pressure switch and tie them together for troubleshooting purposes and this had no effect. So at this point I really don't know what to do.
    Anyone?
    Thanks
    ps0303's Avatar
    Jul 2011
    FL
    3,679
    Re: Raypak RP2100 Cycling continuously: operational, PRS, SPK, operational......
    Check the control board. Sounds like something is shorting it out. I have things like a dead lizard and even a small black snake get up inside there and short things out.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    are you sure you have the correct gas pressures? there hasn't been an addition of another gas equipment put on the gas line?
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    ps0303's Avatar
    Jul 2011
    FL
    3,679
    Quote Originally Posted by malcolmb5325 View Post
    Gas pressure wouldn't cause the unit to act this way.
    Paul
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Quote Originally Posted by ps0303 View Post
    Agreed. You may also want to follow the wires from the pressure switch back to the board and make sure they have not been eaten.
    Factory Warranty Station for:
