Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Bleach vs. liquid chlorine?
    May 2013
    New Jersey
    176
    I have been here for two years so far (love this website!) The past two years I have used liquid chlorine, but I know bleach is also recommended for FC. I have never used bleach before and we are opening the pool tomorrow. I have no liquid chlorine at the moment and have to run out tonight in a pinch to get some but all pool stores are closed. I am thinking of trying the bleach this year instead of liquid chlorine. (For some reason I have been scared to pour straight bleach in but it is identical to liquid chlorine, is that right?) Anyway, what do I get? I'll be going to Wal-Mart. Just Chlorox bleach? Do I need to look for anything in particular? I'll be using the calculator to calculate when the time comes but I assume I'll need more bleach than I did when I used liquid chlorine. Just trying to figure out how many bottles I need.
    Also, is it okay to intermix the two if need be? Say if I start chlorinating with bleach and then switch to liquid chlorine or vice versa, or even if I use both in the same day, is that ok?
    Thanks so much guys!
    7+ years, inground, 25,000 gallon, vinyl, sand filter.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Bleach vs. liquid chlorine?
    Quote Originally Posted by suziequsie2945 View Post
    The only difference is the % in the solution. Bleach is actually weaker than what you have been using. But in the end they are all chlorine in a liquid form. Some just have extra water in the solution.....
    Support the site
    May 2013
    New Jersey
    176
    So good ole Chlorox it is!
    Do you find any difference between the two when using them in the pool? And since they are the same, I assume I can intermix? I see the Chlorox is half the strength.
    May 2014
    Franklin, NC
    9,184
    Yes, intermix away. No difference. And, no need for the name brand stuff. WalMart Great Value is much less expensive than the name brand Clorox. Just look on the side and verify the %
    Support the site
    May 2013
    New Jersey
    176
    Awesome! Thanks! Wish me luck with my opening and I'm sure I'll be back - LOL!
    May 2014
    Franklin, NC
    9,184
    Good luck then - we will be here!
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    Just make sure the bleach is NOT splash-less, outdoor, scented, etc. since these add things you don't want in your pool like thickeners that will foam.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    I buy Kroger brand concentrated bleach at the grocery store. Easy enough to toss a few in the basket when they are on sale. 8.25%. Liquid chlorine is usually 10% or 12%, exact same ingredients.
    May 2013
    New Jersey
    176
    Quote Originally Posted by chem geek View Post
    I just saw this post this morning after I bought 20 bottles of bleach! I just checked and all it says is "regular scent." Anyone know what that means, and is it okay to use that today? That's all I have on hand and I'd like to get some FC in the pool ASAP!
    May 2014
    Franklin, NC
    9,184
    What brand?
    Support the site
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Regular scent is probably fine. I take "regular" to mean unscented... unless someone knows what "regular" smells like?
    Isolated Spa - 345 Gallons
    May 2013
    New Jersey
    176
    Quote Originally Posted by tim5055 View Post
    What brand?
    The Rite Aid Home brand.
    Quote Originally Posted by JVTrain View Post
    I was thinking the same thing. IF it's not okay, what will my pool look like? Foamy? This way I can gauge whether it's adding other unnecessary stuff to the pool.
    It's 8.25% and the rest is "other ingredients." It does indicate no phosphorus.
    May 2014
    Franklin, NC
    9,184
    You are good to go. The MSDS sheet on it lists two ingredients
    Sodium Hypochlorite
    Sodium Hydroxide
    This is normal bleach.
    And to answer your question, yes the splash-less will cause foaming. Almost all of us have grabbed a bottle at least once in the past.
    Support the site
    May 2013
    New Jersey
    176
    Sodium Hypochlorite
    Sodium Hydroxide
    Thank you for looking that up! Good news I couldn't imagine returning 20 bottles back to Rite Aid - LOL
    May 2015
    Wildorado Texas
    252
    Sodium Hydroxide, aka caustic soda, is often used as a stabilizer in bottled bleach.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Bleach is made by passing electrical current through NaOH, so it will inherently contain it as part of it's makeup.
    Essential Links:
    May 2015
    Wildorado Texas
    252
    Quote Originally Posted by Patrick_B View Post
    Yep, forgot that.
    Is IS often added though. Hypochlorite likes it alot.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I did not know that. My industry uses big volumes at such high rates, there is no point in doing that. Interesting.
    Essential Links:
    Mar 2007
    San Rafael, CA USA
    12,082
    If you do not leave some excess lye (sodium hydroxide) in making bleach, then the pH will be lower and the bleach will degrade more quickly. So a small amount is left in. In high-quality 12.5% chlorinating liquid, there's around 0.25% lye and the pH is around 12.5 (with no excess lye, the pH would be around 10.6).
    As for fragrance, that won't cause foaming. It's the thickeners that cause foaming. The fragrance probably doesn't do a lot of harm, but we like to avoid adding anything extra to the pool just in case. It sounds like regular scent is unscented -- it's the regular clean bleach smell.
  20. Back To Top    #20
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I see... It makes perfect sense.
    Essential Links:
