Results 1 to 9 of 9
Thread: Cant get rid of metal stain
    I have a bad iron/rust stain all the way around the liner of my above ground pool. It is 24'x52" so about 14000 gallons. I have put 3 bottles of metal magic let it run for 3 days with somewhat positive results. The bottom cleared up some but the sides were still bad so added 5 lb of vitamin C acid not really any effect un less u place on a sponge directly on the stain. What else do I do?
    Re: Cant get rid of metal stain
    Did you follow the whole AA treatment process, lower PH, eliminate chlorine, etc?
    Yep I did.
    ph was actually 6.8 or lower FC is 0
    this is the acid I put in. may not be right stuff I don't know. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    dang Ijust realized that is citric acid ugggg
    **** **** **** lol
    ok will be Friday before I can get the absorbic acid here do I need to raise the ph some and turn SWG back on for a day?
    ok stain is gone but water is cloudy??
    Cloudy water for one to three days is fairly common right after stains are removed. It might be algae getting started, but more likely it is simply the sequestrant doing it's job.
