Results 1 to 9 of 9
Thread: Help! Mulberries caught in skimmer, now pump not working correctly.
    Mar 2014
    Indiana
    28
    Need some expert advice. Trying to clear up my water so I had the pump running on high while I was gone today. Didn't realize how it windy it was and tons of the mulberry "pods" blew into the pool and clogged the skimmer basket. The water was not getting to the pump and filter. Cleaned everything out, started back up again and the pressure is very low. Some water is coming out the of the return, but not much. Is my pump ruined??
    27' Radiant Metric AGP ~17,300 gallons
    Pentair Clean & Clear 150 sf Cartridge Filter
    1 1/2 HP Dual Speed OptiFlo Pump
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Help! Mulberries caught in skimmer, now pump not working correctly.
    If it overheated you could have damaged the impeller/housing.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Most likely a bunch of stuff made it through the skimmer into the pipe and the pump. Pull the pump strainer basket out. Make double sure the power to the pump is off. Then see if you can't reach up into the pump housing. If you have stuff lodged in the pump impeller, it won't pump worth beans, but it will sound normal.
    22,544
    1+ Richard's diagnosis. Clogged impeller.
    Mar 2014
    Indiana
    28
    Thanks, will check the impeller!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,521
    I turned my pump off and closed the valve coming from the skimmer and opened up the strainer basket and let water pressure from the return side force water backwards thru the pump, and a bunch of junk flushed out.
    Try that and see if it helps.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Mar 2014
    Indiana
    28
    We opened up the pump and low and behold the impeller was almost completely clogged! Thanks so much for the advice!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    I had that happen once with pine-needles. jammed the impeller.
    Dolphin E10 Cleaning Robot.
    Richard320's Avatar
    Jan 2010
    18,984
    Quote Originally Posted by ashpool View Post
    Look how much you've already saved by switching to TFP!
