Thread: My polaris is a stud.....BUT
    Apr 2015
    Richland WA
    55
    I love my Polaris, He (yes ours is a he) does a great job of keeping the pool free of sediments. Unfortunately, he seems to be having a chronic issue with the wedding cake steps into the pool. See this pic:
    He keeps getting stuck in this position. Sometimes he shoots water into the air, other times he just sits there until the return valve kicks on.
    Has anyone figured out a solution to this issue? I've changed his tires, adjusted the jet and still he gets stuck here at least once an hour.
    24,000 gal in ground, Gunite, Sand filter, Hayward 140,000 btu heat pump, Pentair Superflow VS, Polaris pool sweep, TF-100 test kit w/speed stir
    38,371
    Re: My polaris is a stud.....BUT
    No pic.
    To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
    Apr 2015
    Richland WA
    55
    No pic.
    Whoops, thought I had the right links posted. The pics should be showing now. Any thoughts on how to correct this?
    May 2015
    Philadelphia, PA
    3
    Hey! I have a pool that looks just like yours - yours is cleaner though - and I have a Polaris like yours, and steps like yours. I'd say that your Polaris hose is a bit too long. My steps are the farthest point from the Polaris wall fitting - I suppose yours are, too - and my hose is of a length such that the Polaris will make it up the bottom step, but not up on the middle step. (Of course, the tail can whip around up on the top two steps, sometimes).
    True, if you shorten the hose a bit, you might have to give the top two steps a quick brush each morning, but that will rid you of this pesky situation.
    Hope that helps!
    Alan
    And yes, the Polaris ~is~ a stud, isn't it?!
    ~20' x ~40' kidney-shaped outdoor, in-ground
    Pentair WhisperFlo pump, Pentair MasterTemp heater
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    the hose should be no longer than + or - 6" to the furthermost point. To check this leave the hose connected to the wall (with pumps off), disconnect cleaner then walk the hose to the furthermost point, pull to the hose to straighten it then check against the edge of the pool. if you have quite a bit of hose over then you must cut the Leader Hose (hose connected to cleaner) to the depth of the pool, then do a recheck of the length and it is, say 12" too long then you must cut 6" off each "Feeder" hose (1 & 2) from the first swivel from the wall fitting. Then rest the hose floats to be evenly spaced at approx 3' apart.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Apr 2015
    Richland WA
    55
    Thank you for the advice! I had not considered the hose length as the problem. I'll check it out and report back if that solved the problem for us.
