Thread: Adding CYA
    May 2015
    River Falls, WI
    124
    Adding CYA
    If I'm adding cya via a sock in the skimmer do I have to wait a week or so to get accurate readings?
    ~19k Gal, IG Vinyl, Hayward SP2607X10 1hp pump, Hayward S200 Sand Filter, built in 70s, has 8 deep end with diving board, 1 skimmer, 1 return, 1 low hole, Polaris booster pump PB4-60, old Polaris robot not sure model, Rheem P-M266A-EN-C 266,000 BTU heater, solar cover, Taylor K-2006 test kit, Speedstir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Adding CYA
    yes. Give the sock a squeeze a few times a day to speed it up.
