Results 1 to 16 of 16
Thread: Hose Conversion Problem - Coleman 16' x 48" and Best Choice Products Pump/Sand Filter
    May 2015
    Nacogdocbes, Tx
    9
    I have been trying, looking and banging my head going on 1o days now and I will surely appreciate any feedback.
    We bought a Coleman 16' x 48" pool at Walmart.
    My wife read that these paper filter pumps are inadequate, so we bought a Best Choice Products® Pro Above Ground Swimming Pool Pump System 4500GPH 19" Sand Filter w/ 1.0HP
    The hose connections to the pump from the Coleman pool are totally different than what this pump needs, which is a hose end that screws onto the pump fitting:
    Pump fitting:
    Hose from Coleman pool:
    I have chased so things up the wrong tree.
    Is there an easy way to hook these pool hoses to this pump? Any conversion pieces?
    Thank you so much!
    Jimmy
    38,524
    Re: Hose Conversion Problem - Coleman 16' x 48" and Best Choice Products Pump/Sand Fi
    Welcome to TFP!!!
    So often the pool companies use proprietary unions to connect to the pump. I have not idea if there is an adapter.
    It might be easier to just abandon those hoses and find some PVC fittings that will work on the pump. Although then you may need to figure out how to connect to the pool.
    May 2015
    Nacogdocbes, Tx
    9
    That's what I feared. I'm still interested in any solutions that anyone might have.
    Does anyone have any experience hard plumbing an above ground pool? If so, what sort of a PVC connection will work to hook up an in-pool auto-vacuum? That might not work either, but it's worth a shot.
    http://www.amazon.com/Hayward-500-Ab...g+pool+sweeper
    FUBAR's Avatar
    May 2013
    Charleston, WV
    61
    Put a Skimmer in and hard plumb it to the pump. Thank me later. And wow! That pool will be a whirl pool with a pump that size!
    10k gallon 22' AG Vinyl, 2k got Cartridge Filter, Fresh water, BBB Method baby!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,555
    You can make a union with a couple of dollars worth of PVC, like I did here. Just use a straight thru pipe in the middle instead of a tee and put a fitting on either end that works with the two different hoses.
    I think I ought to make and sell these.
    BTW, FUBAR is right that you'd benefit from putting in a thru-the-wall skimmer, but if you're not ready to cut holes in your new pool, this will get you by for a while.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    May 2015
    Nacogdocbes, Tx
    9
    I went to Lowes chasing down a tip that I'd read somewhere else and they did not carry a thorough enough PVC section to plumb it out. There is a dedicated plumbing store that I can fit, but I "think" that I found two pieces that screw onto the places the hose goes that I can clamp the hose to. A lightning storm ran me off yesterday. Leaks of course will not work, so if there are any I'll try hard plumbing.
    Finding a fitting that will work with the proprietary Coleman hoses has been my entire problem, jeffchap. Any fitting. I'm so stressed. The water is getting filthy. as the pool cover does not stay on even without wind and there has been no pumping at all so far.
    I don't entirely understand this photo. Can you explain it? Where do those hoses go? Why are two hoses coming into that single fitting that appears to gr through the pool wall? Maybe it just looks like it goes through the pool wall? Why is a water hose coming into that fitting?
    Quote Originally Posted by jeffchap View Post
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,555
    There's nothing going through the pool wall here. I just zip tied it to the support leg to keep it off the ground.
    The top hose is coming from the pump, and the bottom hose back to the return on the pool. I did this to insert a tee so I could divert some of the water off thru the garden hose to a home made solar heater. You don't need that, which is why I said to replace the tee with a straight pipe.
    Pentair IC40 SWG
    May 2015
    Nacogdocbes, Tx
    9
    Gotcha! Thank you.
    Strange, but our water is still cold too. It won't be long before it gets hot, though.
    FUBAR's Avatar
    May 2013
    Charleston, WV
    61
    Those hoses ends will screw onto 2" NPT fittings. I use heavy duty nylon tape with them if you don't have a rubber gasket.
    May 2015
    Nacogdocbes, Tx
    9
    I have to say that this project that I took on for my wife was the most frustrating thing that I have done in my adult life thanks to Coleman and their proprietary hose connections.
    I was literally on the verge of tears day after day of frustrated looking, calling and searching only to be rebuffed when I got whatever solution that I thought I had found home. The cover does not stay ion the pool either and the water was getting filthy as days ticked on by. The project was a money pit. I had to haul in trucks of fill dirt, level and pack it, then the costs of the pool, pump, chemicals, accessories started adding up like out national debt it seemed there for awhile, but the pool was still non-functionally dirty.
    I am SO glad that I came across this forum. I found a nipple that would work without leaking with a radiator hose clamp holding it on FUBAR. That Chinese pump with no instructions or place to get parts did use standard connections. The Coleman pool was the problem all along.
    The fact that I came across you guys here might have been the small difference between finally getting the pool up, cleaned and going and having a nervous breakdown. Just being here was very powerful to me. Thank you all.
    The 1 HP pump is very, very adequate and the water is crystal clear. That lady bug floor vacuum that my wife bought (pictured above) works like a champ along with the pump sucking up anything that dare sink to the bottom.
    Nirvana. I have reached a state of complete nirvana.
    No wait!! I'm just getting started. I have tons more to learn. Haha
    Thank you again everyone.
    38,524
    Glad you got everything up and running. The Intex use odd hoses as well. And every manufacturer seems to use proprietary fittings on some of their equipment ... very frustrating.
    Now on to the chemical maintenance and enjoying the pool
    Coleman uses the same fittings as the intex, thus could've went with intex sand filter.
    Jun 2013
    Mid-Mi
    21
    Jimmy,
    Sounds like you are set, but there is an adapter that can be used to adapt the Intex/Coleman fittings if they are the larger ones. Here is a link to one of the threads about it: adapter
    I just typed in "Plumbing Hayward pump to Intex Pool" for info.
    I will try to take some pics when I get my new Hayward pump/ filter system hooked up.
    Intex Ultra Frame 20' x 52"
    Hayward Pro 1hp Power-Flo LX/ 18" Sand Filter
    12-4'x8'x1" Polystyrene Sheets
    Jun 2015
    Freeport, Florida
    1
    Quote Originally Posted by Jimmy2015 View Post
    Pump fitting:
    Thank you so much!
    Jimmy
    I think I am late to this party but in case anyone else needs help. I have an Intex 15x48 and I'm on my 7th year with it. I got rid of the pump that came with it AND the hoses. I bought regular 6'x1.5" filter hoses and used hose clamps to clamp them on my new pump
    Im trying to connect this same pump to an Intex 22x52 - any recommendations on fitting?
    33000L Concrete Pool, Viron P320 Pump, Viron-PH Chlorinator, Viron CL400 cartridge filter, Sunlover solar heating
    Jul 2012
    SE Minnesota
    137
    Quote Originally Posted by filetandrelease View Post
    Try this thread.
    http://www.troublefreepool.com/threa...ex-Pools/page2
    The last post on page 2 has this link.
    http://www.game-group.com/products/40mm-conversion-kit/
    Intex Ultra Frame 26'x52"
    Intex 2,500 gal/hr pump with Unicel cartridge filter.
