Results 1 to 10 of 10
Thread: "ATWOODS" pool store for Oklahoma :)
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    So I just returned from Atwoods and thought I would let everyone know the prices and what I found:
    Diamond Solar salt 40 lb (blue bag and Yellow bag) $4.65
    CYA stabilizer 3 lb $ 8.?? something
    10% Clorine bleach $2.99 a gallon (I could not find a manufacture date but there was a use by date of Jan 16??)
    Muriatic Acid 31.45% 20 Baume 1 gallon $3.99
    24 lb DE but can't remember exactly how much it cost (cheap)
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: "ATWOODS" pool store for Oklahoma :)
    Seem to be good prices on the bleach and MA. I only use CYA on occasion and don't use the others at all, so I cannot comment on those.
    A word of advice on the bleach...the first time you use it, I would dose according to what Pool Math tells you. I would then retest FC about 30-60 minutes later to see if the FC level increased as expected for 10% bleach. Without a manufacture date, I would not blindly assume it has 10% strength until you confirm it with this test. The higher bleach concentrations will lose strength faster than lower concentrations under the same circumstances. I ran into the same situation a couple of years ago when I purchased 10% from a big box store. Testing confirmed that it only had 6% strength. Apparently, bleach at a home improvement big box store has much lower turnover than it does at a grocery store or warehouse club.
    Jul 2013
    Fletcher, OK
    3,353
    Thanks for the heads up
    May 2015
    Tulsa/ OK
    4
    I hit our local Atwood's and bought 24 gallons of the 10%. They also at the time ( last week) had 5.25% for 99 cents. I opted for the 10% only because I didn't want to have to haul a bunch more of the lesser strength stuff out.
    May 2015
    Tulsa/ OK
    4
    Also the 10% seemed to actually be a bit stronger than 10% according to the pool math. After adding recc dose it bumped my fc way up. Haven't opened second gallon yet so can't say if its consistent.
    Sep 2013
    Joplin, MO
    74
    I bought from Atwoods last year and it was stronger than 10% at the beginning of swim season!
    Pool Owner since 2013 . 15'x48" AG Intex Metal Frame . 4500 Gallons . Intex 2100 GPH Sand Filter
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I just had that happen with the 8.25% generic bleach from Winco.
    Every gallon of bleach I've added since last year raised my fc 4ppm (usually the generic Safeway brand)
    The winco raises it 5-6ppm!
    Dolphin E10 Cleaning Robot.
    Jun 2014
    Rogers, AR
    424
    Thanks for the heads up! They are around the corner from me and I have never stopped in.
    Here in AR it is $2.50 a gallon. I bought 20 gallons this morning.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    May 2015
    Chickasha, OK
    184
    Thanks for sharing! As soon as my SLAM is done, I'll be shopping at Atwood's for my chemicals. Trying to avoid our local pool store at the moment...
    I told them Saturday that I was trying the TFP method and they were none too happy about it...
    25,000 gallon freeform gunnite/plaster, built in the 1970s/80s; Sta-Rite 9463004 575-lb. sand filter; Sta-Rite DuraGlas/Max-E-Glas (P2RA5F-125L) single-speed 1.5 HP pump, manufactured 12/1993 (1M93M).
    Helpful links: TFTestKits; Pool School; ABCs of Pool Water Chemistry; Chlorine/CYA Chart; PoolMath; SLAM - Shock Level And Maintain
    Jul 2013
    Fletcher, OK
    3,353
    COBRIen, your right up the street, ive been to that Atwoods a couple times... They can be "not happy" as long as your pool is nice and you save money...
    at that price for chlorine, i would go there to finish your SLAM
