Thread: Spa leak?
    May 2015
    Plano
    1
    Spa leak?
    Just had my pool and spa replastered now have leakage of water in spa( about 2.5 inches in 12 hours) Have put in new check valve kits and new jandy valve diverters and serviced the clorinator. Put in new light bulbs and gasket in spa and pool lights . Pool was down for one month renovation and refilled 3 weeks ago Any ideas on where to go next to find leak. mike o'rear [email edited out for spam prevention]
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Spa leak?
    Welcome!
    Try a bucket test on the pool. Sort of. Set a plastic bucket or pitcher or whatever on a pool step and fill it up to weight it down. Then mark the water level. See if the pool level rises overnight. If so, you have a bad check valve or something. If the pool doesn't rise but the spa goes down, you have a leak.
    May 2015
    Moorpark, CA
    171
    Re: Spa leak?
    I have the same situation. If the water in the spa only drops 2.5 inches, will that be enough to see a difference in the pool level?
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
    Richard320's Avatar
    Jan 2010
    19,037
    Re: Spa leak?
    Quote Originally Posted by Michael1 View Post
    That depends on relative surface area. If the spa is 1/10 the area of the pool, you'll see 1/10 the rise in the pool, or 1/4". If the spa is 1/6 the surface area, you'll see 1/6, about 7/16".
    May 2015
    Moorpark, CA
    171
    Re: Spa leak?
    Thanks, Richard. Unless it rains, I guess if you see it rise at all, you pretty much have your answer.
    Michael
