Results 1 to 7 of 7
Thread: When Is It Best To Run Pump
    May 2015
    Chardon, ohio
    22
    I've been running my pool pump pretty much non stop since I've opened. I'm going to try running it a lot less time (like maybe 4-6 hours a day) and see what happens. Water will turn over in 4 hours. Water is crystal clear and water is balanced. Is it best to run the pump at night or during the day with the sun out? Any help would be appreciated. Newbe here. Thanks.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: When Is It Best To Run Pump
    Run it based on price if you have a power company that charges more for peak hours versus non-peak. Early morning or late evening. Also consider when you'll want to check pool chemistry daily. Need the pump to have been running for 30 minutes before sampling to test your water. Turnover is not really something to worry about. Run the pump long enough so that your water is clear and enough to distribute chlorine. My pump runs 5 hours most days. More if I want extra skimming action. If you have a salt water chlorine generator, you may need to run longer depending on output.
    Also, please add the details of your pool to your forum signature. To change your profile and/or signature, select "Settings" (top right under Pool School button). Scroll down (left side) to "My Settings" & select Edit Profile or Edit Signature.
    Isolated Spa - 345 Gallons
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    im assuming you don't have a SWG?
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    4-6 hours is probably fine. Nothing wrong with giving it a try.
    Please update your signature with your pool info as shown here, What we need to know to answer your questions
    May 2015
    Chardon, ohio
    22
    No matter what I do when I put my info in signature it won't display. I've tried it dozens of times and it won't load. Less than 5 lines. Can't figure it out.
    This is what I get every time I try to fill out my signature
    Your submission could not be processed because the token has expired.
    Please push the back button and reload the previous window.
    Trouble Free Pool
    This is what I get every time to try to fill out my signature page
    Trouble Free Pool
    22000 Gallon in ground vinyl pool built in 2000, sanitized with chlorine
    Hayward C900 Cartridge Filter, Hayward Super Pump, 1HP, Single Speed
    Taylor test kit
    I have well water and do not use it in my pool. Have water trucked in when I need it.
    I live in the Cleveland, Ohio area
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I run the pump for 6 hours a day on a timer. I run it usually at night. I also manually run it for testing, adding chemicals and heavy swimmer load.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Dec 2014
    Riverside California
    482
    The OP's question was to run the pump at night or in the day, which is best? I run my pump during the day because the equipment is not far from my neighbors bedroom window and I do not want to disturb them at night. During the summer, night time operation may be easier on the pump because of the heat. I do not know if sunlight plays a factor in helping chlorine do it's job better or not.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
