Thread: Vinyl liner replacement
    Nov 2010
    South Central Kentucky
    283
    Liner was beyond repair so I bit the bullet and bought a replacement liner. The liner is being installed tomorrow. Is there anything I should do to stay ahead of the game when filling? Should I add a little chlorine as it fills? I plan to wait until my numbers are good before I add the salt and get that system going.
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Vinyl liner replacement
    Nope. Wouldn't hurt to put in a gallon of bleach while it's filling to keep things at bay, but probably not necessary if you plan on getting going on it as soon as it's filled.
    Isolated Spa - 345 Gallons
    Jul 2014
    Independence, KY
    234
    If you add bleach be careful, as if there really is not much water in the pool, you could bleach out the liner. And without a pump working, it might stay concentrated in a small area for too long adn bleach out the liner.
    IG W/Vinyl Liner Oval 18x40, 21K gal, Oval 3'-8'
    Pentair Intelliflo VS Pump, Sand Filter
