- Mar 24, 2014
- 2,455
- Plaster
- CircuPool SJ-55
Here's what ABCs says:
Again I should defer to the more knowledgeable members of the forum but I am under the impression that OCLT passing trumps worrying about CH. I think it is a problem only if the water is cloudy but again I'm not sure. Hopefully someone will be along shortly.
CH - Calcium Hardness
Calcium hardness indicates the amount of calcium in the water. Over time, water with low calcium levels will tend to dissolve calcium out of plaster, pebble, tile, stone, concrete, and to some extent fiberglass surfaces. You can prevent this from happening by keeping the water saturated with calcium. In a vinyl liner pool there is no need for calcium, though high levels can still cause problems. A plaster pool should have CH levels between 250 and 350 if possible. Calcium helps fiberglass pools resist staining and cobalt spotting. If you have a spa you might want to keep CH at at least 100 to 150 to reduce foaming.
You increase CH with calcium chloride, sold as a deicer and by pool stores, or calcium chloride dihydrate, sold by pools stores for increasing calcium. You lower calcium by replacing water or using a reverse osmosis water treatment.
