Thread: Aquarite not generating again
    Jun 2013
    Dallas, TX
    105
    Last year my aquarite had the resistor go out. I replaced it and all has been fine. Now this year, my Compool is having issues and it now appears my aquarite isn't generating again.
    I had thought the pool turned green due to massive rainfall and/or a flood however I just discovered my aquarite doesn't have the generating light on.
    Could low salt (2100 after the rain last week) be causing this? I took off the cover to see if it was the resistor again, but hard to tell since the board is still burned from last time...
    35k gal, sand, IG, diamond brite, Hayward Goldline T-CELL-15 Turbo SWG, Aquarite, Compool Lx3600
    Re: Aquarite not generating again
    If the current limiter burns out the instant salt reading will always be zero. If you have an instant salt reading above zero, the current limiter is still working.
    Low salt is indeed a problem for the AquaRite. Low salt readings can also be caused by the current limiter burning out in the last 24 hours. Once it burns out the salt reading will drift down to zero over 24 hours.
    Jun 2013
    Dallas, TX
    105
    Quote Originally Posted by JasonLion View Post
    Would low salt cause the unit to switch off generating — ie: the generating light isn't on? If so, that's an easy fix.
    Yes, around a salt level of 2300 or lower the unit will shutoff and refuse to turn on again until salt is raised. From 2300 to 2600 the salt light will flash, but the unit will continue to operate.
    Jun 2013
    Dallas, TX
    105
    Good news, thanks! I'm grabbing more salt tonight, so hopefully this solves the issue.
