Thread: Too much suction when vacuuming
    May 2015
    Thornhill
    2
    There is too much suction when I vacuum the pool. I use a vacuum head that has wheels but it still doesnt work. The head routinely gets stuck on the vinyl liner. Does anyone have suggestions?
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    Re: Too much suction when vacuuming
    mine came with an adjustable regulator valve that allowed you to decrease the suction. i tossed it because i had just the right amount. this is the one that came w/ the poolvergnugen. im of course assuming you have a suction side vacuum, which may not be the case.
    [IMG][/IMG]
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Welcome to TFP!
    Wheeled vacuum heads are generally not intended for vinyl pools. You want the kind that has brushes to prevent sticking.
    May 2015
    Thornhill
    2
    Thanks for the advice. Ill talk to my local pool store to see what they have.
