Thread: Anyone regretted an acid wash?
    May 2015
    Las Vegas, NV
    3
    After lots of surfing through the boards.... I just wanted to ask owners who did get an acid wash....
    Have any one of you that has done an acid wash regretted it?
    Example : Has the pool surface been too rough after? Or has the plaster deteriorated faster?
    Are the con's true to be problemantic?
    Re: Anyone regretted an acid wash?
    An acid wash does remove plaster, and thus shortens the lifetime of the plaster. For most people that effect is invisible until many years later. Having anything go wrong immediately is quite unusual.
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Only had one done after the plaster was installed. Evened out the plaster and exposed the aggregate quite nicely. Beyond that, I think it's a fairly safe procedure unless your plaster is on its last legs. I agree with Jason, though, it does remove plastered can definitely shorten the life span of the plaster.
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    Iwejun's Avatar
    May 2014
    DFW
    10
    I did my acid wash last spring and I don't regret it at all. It was terribly easy to do just please remember to have all the safety equipment especially the correct respirator and I wore Tyvek coveralls bought at Lowes. Took all of a couple hours and was a night and day difference. On top of that the pool experts wanted around $700 to do it and I spent maybe $200 and it fixed my high CYA problem
    14,300 gallon plaster, built 9/2001, SWG Goldline T15, generic, 2hp Challenger pump, Polaris 3/4 booster, DE less filter cartridges in 017 Letra Legend creepy(rebuilt,rebuilt,rebuilt) 40 k BTU heater, new Pebble Tech in 2017.
