Results 1 to 10 of 10
Thread: Do I need to do anything else?
    Jul 2013
    Lake Charles, Louisiana
    32
    Using my TF-100 test kit here are my current results:
    FC 6
    CC 0
    TC 6
    TA 120
    CH 300
    CYA 40
    Cl 3
    pH 7.5
    Br 6
    Salt 2900
    First off my water looks great! Now my question is should I be concerned with other things that my kit does not test for? Reason I'm asking is because I have had a serious increase in water bugs / back swimmers? I've been reading and have discovered that they feed on algae, and saw suggestions of shocking the pool. I've never shocked my pool being as the water has always looks so good. Is shocking something that I need to consider if so how much and of what? Lastly are there any other things I need to look for that could be hazardous to us swimming and not tested in my TF-100? Reason I ask is because last year I had brought the water to be tested by one of the pool companies, they had mentioned something about mustard algae, I believe? Not quite certain if that's what they said but it was just something in the water that I was unaware of that they said could be hazardous. They were probably trying to upsell me on something but I just want to make sure and get some opinions.
    Thank you guys in advance
    IG vinyl built 7/1/13, 30,000 to 30,500 gal
    Pentair TA-100D Sand Filter
    Hayward T-Cell-15 Chlorinator
    Pentair Superflow Pump 1.50 hp model # 196239
    Hayward Goldline Pro-Logic
    Re: Do I need to do anything else?
    You can get rid of the backswimmers by adding borates. Shocking only helps keep them away for a little while, and isn't really a solution.
    The store was just trying to sell you things you don't need by mentioning levels that don't matter and implying that they were important.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    I've been only testing with my TF100 for 3 years. I've never shocked my pool. You are good to go! Nice numbers!
    Just make sure that FC stays above the minimum for your CYA on the Chlorine CYA Chart at all times and you will never grow algae. I dose with bleach in the winter when my SWG stops producing chlorine. I also dose with bleach from time to time as chlorine demand exceeds my current SWG setting. From lots of swimming, lots of tree debris, etc.
    Have you read the Water Balance for SWCGs?
    robbief00's Avatar
    Dec 2014
    TX
    40
    I also have good test numbers and crystal clear water but started noticing approx 5-10 backswimmers in my pool daily. I have been scooping them out but more will show up again in a few days. This is my first pool and only been filled for a month or two so I don't know if it is a seasonal thing that will eventually go away, due to all the heavy rain we have been getting lately, etc...
    My Pool Build
    15k gal IG freeform w/ attached spa, Wet Edge Luna Quartz Bermuda, 3.5' to 5.5' depth, Intelliflo VS pump, Cartridge filter, MasterTemp heater
    1 hp Whisperflo for ledge bubblers/weeping rock wall, Polaris 280, EasyTouch 8 Automation, Intellibrite 5G color LED's, TF-100 w/ Speedstir, Stenner Peristaltic Pump
    Isaac-1's Avatar
    SW Louisiana
    6,711
    There is only so much you are going to do about insect activity in SW Louisiana this time of year, particularly with all the rain that has been going on, and the hot humid conditions.
    Jul 2013
    32
    Quote Originally Posted by JasonLion View Post
    Hey thank you all! Jason i've never used borates but I'm seeing that my pool would require about 91lbs if my calculation is correct. How would you recommend me adding it to my pool?
    Thanks again
    Boric acid is a very convent way to add borates, though you do need to order it over the Internet, as it is almost never available locally. For 30,000 gallons you will need about 72 lbs. Duda Diesel is a good place to order from.
    Jul 2013
    32
    Thanks Jason,
    Which would be better the Granular or Powder Boric Acid? Also what method should I use to put it in my pool?
    Thanks again
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    My pool took 12 boxes of Borax to raise the Borates to 50, so your looking at 30 boxes.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Here are the instructions I followed. It was easy and fun. I split it in half as the author suggested.
    http://www.troublefreepool.com/threa...ol-Why-and-How
