Results 1 to 8 of 8
Thread: Rope Lighting
    May 2015
    South Park, PA
    39
    Rope Lighting
    Thinking about putting LED rope lighting on top of the fence surrounding my pool. Then connect the circuit to a SunTouch controller using an Aux relay. The wiring is no problem.
    Finding 120V LED rope lighting is the problem. Almost purchased all the accessories (2-150ft spools of lights, connectors, power supply, etc.) and noticed an $80+ shipping charge on checkout (online purchase).
    Anyone know of any sources for LED rope lights with free or reasonable shipping?
    Thanks.
    30,000 gal inground (20 ft. x 40 ft. w/ deep end), vinyl liner, Pentair Clear & Clear 420 cartridge filter, single speed 1.5 HP Pentair Whisperflow pump, heat pump, SunTouch controller
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Rope Lighting
    How's 12 bucks for 18 feet? Out-of-season Christmas decor. http://www.acehardware.com/product/i...450739.1259064
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,205
    Re: Rope Lighting
    And you can connect them end to end for your desired length.
    Coaxial connector can connect up to 200 ft. total rope lights
    Support the site
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Rope Lighting
    you want to have fun, get these I love LED's
    Intermatic ML600TW Low Voltage 600-Watt Power Pack
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    SPI Controller WiFi Controller WS2811 WS2801 6803 1903 LED Strip & Remote WF300
    http://www.ebay.com/itm/281635728360...%3AMEBIDX%3AIT
    12V WS2811 1 IC- 3LEDs 30 48 60 leds/m Digital Dream Color LED Strip Light
    white PCB, 60 LED/M, IP68, 20 Meters...
    http://www.ebay.com/itm/311113572503...%3AMEBIDX%3AIT
    and this is what it looks like, I did it on my cieling first but I am doing for the pool also..
    https://www.youtube.com/watch?featur...&v=09eEdbpb-nI
    Mar 2015
    Tulsa/Oklahoma
    68
    Re: Rope Lighting
    Quote Originally Posted by cowboycasey View Post
    Now that is pretty cool looking! If I can get my wife to go for something like that... She's always got to be conservative...plain boring white lights.... So how waterproof are these? Have you tried them outside?
    1972 - 22,500 gallon, In-ground Kidney shape Gunite pool built by Fiesta pools (2015 remodel), Sta-Rite sand filter Model 9462404 side mount ( Triton II TR60 is newer Equivalent), 3.1 sq ft., Pentair 011018 IntelliFlo Variable Speed Pump, Leslies Coppertherm (Raypak) PL 260AEN 260,00 BTU Heater, Anchor Defender Mesh Safety Cover, Taylor K2006 test kit, Dolphin Z5 Robotic Cleaner
    Jul 2013
    Fletcher, OK
    3,353
    Re: Rope Lighting
    I have IP67 under my eaves and have had no issue with them.. The type of those are IP68, so you can submerge them under water up to 3 meters forever I have them but have not yet put them up, still waiting on my pool build...
    here are video's of the IP67 LED's under my eaves, they are washing the brick pointing down and the Christmas tree on the left...
    hope you like Christmas
    https://www.youtube.com/watch?v=5o350naIYsQ
    https://www.youtube.com/watch?v=wneGCf1FvSk
    https://www.youtube.com/watch?v=y_xctPhn6rU
    Ok, so maybe I am an LED Super Freak
    PS: they will do solid white, blue, green, pink and 3 others, they are directional though, about 170 degrees angle, rope lights are 360...
    May 2015
    Tulsa/ OK
    4
    Re: Rope Lighting
    That is very cool. So did you buy all your lights from the links you listed in previous post? What I'd like to do is put a couple of strips under the edge of the capstone along the back retaining wall on my pool. My only concerns would be how they weather and a way to attach to the stone that would not look bad and still be removable if need be.
    Jul 2013
    Fletcher, OK
    3,353
    Re: Rope Lighting
    I did buy 40 meters of those lights in the link, they are very nice lights and we'll made... I have not had a chance to light them up yet but they should be fine... You could place them with epoxy, you would be able to chip them off if you ever needed to replace them.. You would need a way to keep them on the rock while the epoxy was setting, some kind of clamp or something
