Results 1 to 7 of 7
Thread: Auto fill
    May 2015
    Windermere
    3
    Auto fill
    We have auto fill on our pool. It was recently adjusted by our pool tech and now the water constantly turns on and off instead of running for long periods of time until it is at the correct level. Should it be constantly turning the water on and off?
    38,361
    Re: Auto fill
    Welcome to TFP!!!
    Is it a standard float valve auto-fill?
    If so, it is normal to turn on and off when the water is at the correct level. Maybe they set it to a position other than where you think the water should be.
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    Re: Auto fill
    if its the float kind, mine does that too - just adds a little bit at a time when it needs it. sounds like no big deal.
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Auto fill
    Welcome to TFP! Sounds exactly like what mine does, the water level moves up and down slightly with waves, wind, etc and turns it on and off frequently. It only runs for a long time when the water level is low and needs to come up an inch or more. We have an overflow drain and I like to keep my water level about 3/4" below the bottom of te overflow grate so it isn't causing more overflow.
    May 2015
    Windermere
    3
    Auto fill feature
    Our auto fill feature used to run water into the pool when low and do so by coming on and staying on until the water was at the desired level. Our pool cleaner today was messing with the float and now the water comes on and shuts off constantly since that time. Does anyone know what needs to get corrected?
    Dec 2014
    West Hills, CA
    157
    Re: Auto fill feature
    is the pool going HIGHER than the level you want it at after the adjustment? when it gets close to the limit, the float will bob a little bit and trickle water in until it hits the right level and turn on and shut off only letting in a small amount of water at a time. eventually, it should stop.
    If it doesnt and the water is higher or as high as you'd like. just readjust the float until it does stop. theres usually a set screw you unscrew and then move the baloon where you want it...then retighten.
    Normally, if there are waves in the pool an auto-fill will tend to cycle on and off. If the water is calm it will come on and stay on until water gets to the correct level.
