Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Exterminating for Spiders around Pool
    VetteBlue's Avatar
    May 2015
    Maryland
    23
    Anyone exterminate around their pool for spiders? The wolf spiders seem to love the pond stone around my pool, and the surface of the water. Big and small, we seem to be providing multi family living for these nasty bugs. I know most of the folks here DIY their water management. Does anyone do their own pest control around their pool? I've seen some threads on here. But they seem to indicate use of home center type pesticides and not the professional stuff.
    I am considering using Suspend Polyzone to eliminate the bugs around the perimeter of our pool, but not within 3 feet of the pool water. Wondering if anyone has used professional chemicals like this, or Demand CS to control the bugs in and around the pool?
    17x35 Oval In Ground Vinyl Pacific Pool, Pentair Intellichlor IC40 SWG, Sand Filter, Pentair Kreepy Krauly Legend Pressure Side Cleaner, LED Lighting System, 16 Mil Clear Solar Blanket, TF-100 Test Kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Exterminating for Spiders around Pool
    I use CyperWP for wolf spiders. I get skimmer baskets full of them if I don't spray, though most of mine show up in the late summer. It's a permethrin derivative that does a good job on them. Of course you have to reapply it regularly since it isn't weatherproof like the ones you mentioned.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I leave all ours alone, and release alive all the spiders caught in the skimmer. I'd rather have them roaming around than the brown recluse in my garage. Sorry I couldn't help.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    My daughter also had a spider problem around her pool and property. The exterminator she hired told her that spiders are very difficult to control because their body does not contact the surfaces that have been treated. He told her that to control the spiders she needed to control their food source. By treating for other bugs, the spiders eventually disappeared. She now spreads a granulated insecticide around her house and pool to control the bugs. No more spiders.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    SW Indiana
    9,199
    Quote Originally Posted by n240sxguy View Post
    I actually have had flow issues with my skimmer in the past from the basket being full of spiders. By full, I mean more in the skimmer than the basket will hold. Wolf spiders roam open fields in insane numbers in some areas.
    Jun 2014
    15,274
    We're having a busy Wolf spider season already as well. For the first time I decided to spread the typical Ortho granule pesticide around the perimeter of our pool to try and knock-back the numbers we find in the pool/skimmer each day. Scorpions increasing as well.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by JohnT View Post
    Good gosh. Yes, by all means nuke them when they get to that number.
    wjr75's Avatar
    Jun 2013
    IL
    836
    This suff might (edit "Will") work..Had an invasion of little red spec spider bugs (Clover Mites) and this wiped them out. Bought it on Amazon a few years back. Also need a pump sprayer.
    7.9 % Bifenthrin Pest Control Multi Insecticide
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    VetteBlue's Avatar
    May 2015
    Maryland
    23
    The Suspend Polyzone is Deltamethrin 4.75% which targets a wide spectrum of pests including Ants, bed bugs, boxelder bugs, brown marmorated stink bugs, carpenter ants, carpet beetles, centipedes, clothes moths, cockroaches, crickets, earwigs, firebrats, fleas, flies, fruit flies, gnats, hornets, millipedes, moths, multi-colored Asian lady beetles, pillbugs, scorpions, silverfish, spiders, ticks, wasps, yellow jackets -- none of which we want to swim with.
    And it has a polymer which keeps the rain from washing it away. Received my bottle yesterday so once I treat I'll let you know how much spider and bug carnage I witness.
    MiaOKC's Avatar
    Apr 2012
    Oklahoma City, OK
    347
    I am so regretting opening this thread. I've got the heebie-jeebies now! I thought my mama wolf spider who likes to swim with me was bad when I tried to help her out of the water... baby spider explosion! But more than can fill the skimmer? Gah! We have had at least a half dozen black widows take up near the pool. They do not get to stay.
    35,000 gallon gunite pool, semi-T-shaped, 29x15 shallow end and 16x22 deep end, built in the mid-1970s and renovated 2013-2014 // Polaris 9300 Sport robotic cleaner // Taylor K-2006 ... Learning as we go and so grateful to everyone here for their help! Our reno thread
    VetteBlue's Avatar
    May 2015
    Maryland
    23
    Quote Originally Posted by MiaOKC View Post
    I have a house full of girls. Spiders in the same zip code are a general problem. But spiders in our pool is not even an acceptable consideration.
    May 2015
    Dillsburg/Pa
    17
    DITTO! Sad, but I make my wife dispose of spiders. I am a terrible husband haha!
    10k gallon IG with vinyl liner, SWG, MasterTemp 125 Natural Gas Heater, Hayward Cartridge filter, TF-100 Test Kit, Taylor K-1766 Salt Test, Pool Blaster Max, with water fall feature
    May 2015
    Dillsburg/Pa
    17
    OK, so yesterday there was a large spider floating on top of my pool. I skimmed it out and hit the skimmer on the concrete a bit to get the spider off and hundreds of baby spiders began to scatter! It was terrible. I instantly started doing my best irish dance and killed as many as possible. Otherwise, I would have had these suckers living everywhere.....including my pool. I now need counseling
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    I used to hate spiders but I hate mosquitoes more. I do my best not to disturb spider webs nowadays.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Since I have brown recluses, most people in this part of the U.S. do, I just know I do; I try to keep as many good spiders around as I can to deplete their food supply. This little guy has been known to actually hunt brown recluses. Unfortunately I've only seen one of that specific type. It's a daring jumping spider. Really cool to watch.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,556
    All spiders except black widows and brown recluses are welcome to stay around our place. We actually stopped using our back door once to avoid tearing down an orb weavers' web. The kids watched her for weeks and named her Charlotte. No woven messages from her, unfortunately. Maybe you have to have a pig as well.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I move them to the fence area or garden, my wife hates it but I love that they eat flying things like the helecopter mesquitoes we have here.
    May 2015
    Dillsburg/Pa
    17
    Quote Originally Posted by jeffchap View Post
    For whatever reason, orb weavers dont bother me a bit!
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by Mmurray52 View Post
    Even when I was terrified of spiders, orb weavers and black widows didn't bother me much. Now I respect them all. After reading a lot about and watching the brown recluses, right before I kill them, I understand and respect them for what they are. They are very interesting spiders. I just can't leave them around and risk the possible damage from a bite. They really aren't out to hurt anyone, but an unfortunate meeting can have bad consequences.
  20. Back To Top    #20
    VetteBlue's Avatar
    May 2015
    Maryland
    23
    So the update here is, Friday night I had a big wolf spider on my solar blanket. When I went to move it, she got a lot smaller and six hundred babies plunged into my pool. There are 4 girls in my house so spiders aren't desirable ever. Saturday morning, I sprayed the professional stuff and the only bugs I have left are the black water bugs.
    I bought and used Suspend Polyzone from Do My Own Pest Control dot com. (Not trying to spam that's why I didn't link it, but I know you guys like to DIY stuff and pest control is about 90% labor.) This version of Suspend has a polymer to prevent the rain from washing it away. I mixed it at the milder concentration, not their maximum. I sprayed it with a hand sprayer around on the pond stone which borders my concrete pool deck. So far, spiders are gone except for a few random babies still clinging to the side of the pool or other non treated hiding places. Very pleased with the initial results. May treat again in 21 days. One bottle should last for years.
