Results 1 to 9 of 9
Thread: Raypak heater - BTU rating
    Hello,
    I'm planning to buy a new in-ground pool heater to replace my 13-year old Minimax NT 300.
    I'm looking at a RayPak 336 NP electronic model.
    Both the Copper and Cupro-Nickel models are the same price.
    My question, looking at the heater specs it appears to me the Cupro-Nickel uses less energy?
    The only BTU specs I see are "input", what is the actual BTU "output" for the 336 model?
    http://www.raypak.com/product.aspx?i...3-78A6471032E8
    Input BTUH Copper Cupro-Nickel
    P-R336A 332,500 300,000
    Thank You
    Feb 2014
    Upstate, NY
    390
    Re: Raypak heater - BTU rating
    I'm no expert, but I would guess that is the actual BTU rating of the heater. 332,500/300,000 depending on what model you purchase.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Welcome to TFP!
    All of the Raypak gas heaters are right around 81% efficient. The larger the input rating, the faster they put heat into the pool.
    Feb 2014
    Upstate, NY
    390
    Here is what I found: BTU input x total efficiency = BTU Output
    Thanks guys for the quick replies.
    SO I was thinking "input" meant the amount of energy used.
    But it appears from your comments the copper heat exchanger is more efficient.
    332,500 x .81% = 269,325 BTU output
    Thanks for the help!
    Mar 2011
    441
    Quote Originally Posted by jsour View Post
    Typically copper is 2% more efficient.
    20X40 30,000 gallon gunite pool
    Thanks, I went ahead and ordered the heater from inyopools.com today.
    Thanks everyone for the help
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Keep in mind that if you have issues, it might not be covered under warranty. Raypak does state that their units are not to be sold over the internet. I'm not telling to be mean, I just want you to be aware of potential warranty issues.
    These units are all 82% efficient.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Quote Originally Posted by ps0303 View Post
    Point well taken.
    I live in the Northeast and the heater is in use less then 4-months, then come next year when I reopen the pool it will be out of warranty anyway.
    For the price I figured I can purchase a replacement part if the warranty is not honored.
    I am using a local certified installer that moonlights to install the heater.
    Thanks
