Become a TFP Supporter Pool School
Results 1 to 11 of 11
Thread: Umbrella Sleeve in Pool?
    Junior Member
    Jun 2008
    Columbia, SC
    12
    We have just started our pool build (I'll post photos soon) and the PB is planning to do the gunite next week. We have a tanning reef/ledge in the shallow end and are considering having an umbrella sleeve put in there. Any thoughts? Thanks!
    Re: Umbrella Sleeve in Pool?
    Friend of mine had that put in and never used it. Also, if you have a SWG pool, the pole you put in there may rust.
    I bought some cheap metal hangers to put on my fence to hold my brush pool pole. The end that the brush rests on is already turned to rust and the other end is fine. Guess the saltwater eats it up.
    25,000 gallon freeform inground gunite pool with 12" raised spa. 3.5'- 6.4' deep.
    2 skimmers, 6 returns and bubbler on sunshelf.
    Jandy 1.5 hp pump, Jandy valves, Jandy CL340 cart filter, Jandy Aquapure 1400 SWG, Polaris 280 w booster, Jandy LXI 4000 heater.
    White plaster, flagstone coping, custom tan tiles with decos on raised spa.
    Pentair lights.
    650 sq ft concrete deck.
    Senior Member
    Jul 2007
    Suwanee, GA
    527
    Our umbrella was in all summer. It's nice to have some shade from the afternoon sun.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Senior Member
    Sep 2007
    Lafayette, Louisiana
    344
    I have a large tanning ledge and actually put two sleeves in so I can move the umbrella as the sun moves. I keep an umbrella in it all the time and am very glad I have them. I don't see any reason at all to skip them. Even if you don't end up using them alot, they are very small items and have covers you can install so debris doesn't fall in them...or toes. I have been using cheap aluminum pole umbrellas and haven't had any problem with corrosion. The umbrella will fall apart before that aluminum corrodes. Don't use a tight fitting wood pole because the wood may swell and get stuck.
    There are plastic sleeve or bronze. If you use the bronze sleeves, make sure your PB bonds them to the rebar.
    S.R. Smith makes a very good quality bronze sleeve. I can't remember the name of the manufacturer for the plastic ones, but your PB should be able to get them too.
    Jim
    Fortune favors the well prepared
    The build...
    viewtopic.php?t=3974
    Freeform 24' x 38' IG gunite. 3 1/2' to 8' deep. 28,500 gallons. AutoPilot Total Control SWCG. Pentair Intelliflo VF. Pentair CCP520 cartridge filter. Colorlogic LED lights. Tahoe Blue Diamond Brite. 1200 sq ft stamped concrete deck.
    More details as they happen...
    Junior Member
    Jun 2008
    Columbia, SC
    12
    Thanks, everybody, for the replies! We live in central SC where it gets VERY hot in summer. Jim and crabboy, I bet you both can relate given where you live. I'd like to keep the direct sun off the kids (and me) as much as possible so we thought the umbrella sleeve in the tanning ledge would be a good idea. I'm glad to hear that you, crabboy, and you, Jim, like yours. Do either of you have SWG pools? That's what we're going with and I'm just wondering if we can get away with an aluminum pole.
    Senior Member
    Sep 2007
    344
    I do have a salt water pool and haven't noticed any corrosion issues on the umbrella poles. It would take along time for that aluminum to corrode up while submerged. I would really only be concerned mild steel or low quality stainless, or possible where aluminum would be in direct contact with another carbon steel. The fabric of the umbrella or moving pieces will likely wear out before corrosion of the aluminum pole would ever be a problem.
    For the minimal expense of adding a couple sleeves at some convenient places, why not do it? You can not add them later.
    Jim
    The build...
    Junior Member
    Jun 2008
    Columbia, SC
    12
    Thanks, that's very helpful. I was considering an aluminum pole umbrella from Overstock.com after a recommendation from another forum. I figure at the price they're charging (less that $100) for an 11ft diameter umbrella, it doesn't have to last forever. Thanks again!
    Senior Member
    Jul 2007
    Suwanee, GA
    527
    Yes, I have a SWG and an aluminum pole. After one season, the pole still looks good as new. The sleeve that the PB put in is a bit bigger than the umbrella pole I have, so I use a short length of 1 1"2 PVC to fit between the pole and the sleeve so it does not wobble.
    Gary
    Junior Member
    Jun 2008
    Columbia, SC
    12
    Thanks for the info, crabboy! And for the suggestion about the PVC pipe. After hearing from you and Jim, I'm trying to figure out where else I can put umbrella sleeves.
    Senior Member
    Sep 2007
    344
    I put an umbrella sleeve in the concrete deck where I have a table too, so I don't have to use one of those weighted bases that blow over. Just remember the bronze ones have to be bonded to the rebar grid in the concrete.
    The build...
    Junior Member
    Jun 2008
    Columbia, SC
    12
    I'll keep that in mind. Thanks again, Jim.
    Rebecca
