Thread: Question about pool light in deep end
    May 2015
    TN
    312
    The previous owner states that the light hasn't worked in some time. It is mounted in the deep end. I noticed the outer gasket that is attached to the actual globe part is all brittle and broken. Then there is a "plate" up against the wall. I could care less if the light works. I am just curious if it can leak with the outer gasket busted or if it would have to be the flat plate that is against the vinyl wall.
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    30,419
    Re: Question about pool light in deep end
    The pool light is designed not to leak regardless of the gasket condition.......no worries.
    May 2015
    TN
    312
    the pool light is designed not to leak regardless of the gasket condition.......no worries.
    thank you!!!
