Results 1 to 16 of 16
Thread: Hello from Sedalia Missouri!
    mustanglady1111's Avatar
    May 2015
    Sedalia MO
    6
    Question Hello from Sedalia Missouri!
    I've had above ground pools at my disposal since I was 14.
    My parents always used chlorine tabs and algecide etc.
    I guess we follow what we know. I've had 2 vinyl pools
    of my own since.
    Have never had much of a problem using the traditional
    Chemicals.
    I've been reading a lot of info on here and I'm still on the fence.
    When I read chlorine bleach I thought what? I just installed a
    beautiful new liner and it worried me. Understandably the cost
    seems much cheaper than traditional Chemicals but do you have
    to monitor them every day. I've never had to before.
    Not to mention hauling in all the jugs of bleach.
    I guess what I'm asking, is it all worth it?
    Round above ground 7,600 gal.
    1hp Hayward sand filter. 1 yr. old
    Brand new liner. 💗
    Re: Hello from Sedalia Missouri!
    Welcome to TFP!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Hello and welcome, a lot depends on what you consider acceptable, is cloudy water and kids with burning red eyes acceptable? Is fighting algae and adding lots of expensive chemical acceptable, If so stick with the traditional pool store methods. If you want to be rid of these problems and take control of your pool, and save money in the process at the cost of spending a little time learning about what your pool needs and how to provide it, in the form of education you can get here online, and water testing you can do yourself spending about 3-5 minutes per day to start with and with time and experience cutting that down to 2 minutes per day and 3-5 minutes 2 or 3 times per week worth better quality water at less expense, all we ask is that you invest in a quality test kit so you can have reliable numbers to go by, sure this cost money, but it is less than most people will spend on snake oil products after a single trip to the pool store.
    May 2015
    Sedalia MO
    6
    I guess reading so many things in a brief
    time was overwhelming ��
    I absolutely want better water and when you
    put it that way, only a few minutes, it's totally
    doable.
    Guess I need a good test kit. ��
    Brand new liner. 💗
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    So worth it. The quality of water is amazing. And easy! It is water so good you won't want to swim in other people's pools.
    Here are some intro Pool School articles to read and see what you think.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals
    Use PoolMath to figure out how much to add.
    May 2015
    Sedalia MO
    6
    Thanks for the links.
    I did a pH test just after filling with no chemicals
    at all and it was 7.6
    Used a cheap OTO test kit. I'm going to give
    this a try because who doesn't want better water!
    Brand new liner. 💗
    DFW, TX
    24,497
    Test Kit Comparison. Check this out. I use the TF100 from tftestkits.net.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum Mustanglady
    In your pool, that will be very little Bleach to haul, and once you get to know what your pool does, every day testing won't be something you wind up doing. A lot of people end up enjoying it, mostly because they gain a much better understanding of exactly what is going on, and how the chemistry works. Most of all though, because they gain tight control of everything, and there's never any more guesswork or wondering what went wrong in the pool. One of the side benefits is how easy it is to keep a perfect problem free pool.
    Once in the water, Bleach is the same as any other form of Chlorine, and no more likely to fade, or damage a liner than any other type.
    Essential Links:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    May 2015
    Sedalia MO
    6
    Will do! BTW your pool is phenomenal!
    Quote Originally Posted by pooldv View Post
    Brand new liner. 💗
    May 2015
    Sedalia MO
    6
    Quote Originally Posted by Patrick_B View Post
    Can't wait to get started and really enjoy that beautiful new liner!
    Do these same type chemicals work for my hot tub also?
    Brand new liner. 💗
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Quote Originally Posted by mustanglady1111 View Post
    Yes they do
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    May 2015
    Sedalia MO
    6
    Quote Originally Posted by Defgufman View Post
    Yes they do
    That's awesome too!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    They do, but hot tubs are a little different as you have a smaller body of water with more FC swing and higher temperatures that make reactions go faster.
    DFW, TX
    24,497
    Thx
    We can help with your hot tub too. Many of us have them. I maintain mine with bleach and this process.
    http://www.troublefreepool.com/threads/9670-How-do-I-use-Chlorine-in-my-Spa-(or-pool)
    Casey's Avatar
    SW PA
    10,446
    Welcome! TFPC is the only way to go! You'll never experience better water!
