Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: need help after first test
    eazy's Avatar
    May 2015
    puyallup, wa
    11
    tc 1.0
    fc .6
    ph 6.8
    ta 110
    water is cloudy. I assembled and filled pool with tapwater on Sat 5/16. 4440 gallons 15 x 48 intex
    4440 gallons,intex round 15 x 48, ag, cartridge filter, krystal clear 637r filter pump,assembled and filled 5/15/2015
    poolmaster premier deluxe 5 way test kit, tap water
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: need help after first test
    All I can tell you from that is your pH is too low, the limit of the test is 6.8 so it may be even lower than indicated, and chances are your FC is too low, but we can't tell for sure without knowing your CYA level. What chemicals have you added so far?
    eazy's Avatar
    May 2015
    puyallup, wa
    11
    Quote Originally Posted by Isaac-1 View Post
    Friday: 7 ounce shock. 5 lbs ez clor calcium elevator. 2 lbs ez clor clor save.
    back to pool shop with water
    Saturday: 4 ounce ez clor ph up. 1ounce ez clor shimmer and shine. 2 lbs ez clor clor save stabilizer.
    Monday test myself with 5 way kit in blue box.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP!
    Any idea what your CYA level is?
    Here are some intro Pool School articles to read
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals
    Use PoolMath to figure out how much to add.
    38,274
    Welcome to TFP!!!
    Can you define what "7 oz of shock" means? That could mean about 10 different products all with different effects.
    I am not sure what all those products are that you are adding, but I am sure they cost more money than the grocery store equivalents:Recommended Pool Chemicals
    Given the size of the pool, you may want to review and follow this method: http://www.troublefreepool.com/conte...emporary-pools
    eazy's Avatar
    May 2015
    puyallup, wa
    11
    Welcome to TFP!!!
    I used 7 ounces of --E-Z CLOR – SUPER SHOCK-IT 73%--This premium grade fast acting calcium hypochlorite granules that can be broadcast directly into the pool, eliminating messy mixing. Restores sparkle and sheen to pool water as it kills germs, destroys algae and organic contaminants. Super Shock-It contains 73% available chlorine.
    Going to study the links you posted, thank you.
    38,274
    OK, so that is cal-hypo and is adding calcium (CH) to your pool. It is also a possible source of the cloudiness.
    Generally it is easier to just stick with liquid chlorine.
    eazy's Avatar
    May 2015
    puyallup, wa
    11
    I am working through the links. I am moving to household bleach. Is it true that bleach takes the place of both the shock treatment and the dispenser with pucks.
    I should just take the dispenser out and test the water each day and add bleach to keep the fc between 1 and 3?
    38,274
    Trichlor tablets add FC and stabilizer (CYA) and lower the pH. The stabilizer builds up and requires you to maintain higher FC levels. See FC/CYA Chart.
    It is usually easier to just add the CYA separately to hit a target (30-50ppm) and then maintain the FC daily using bleach.
    If you maintain the FC above the minimum for you CYA at all time, algae will not grow and there will never be a need to "shock" on some schedule.
    eazy's Avatar
    May 2015
    puyallup, wa
    11
    results for 5/19/15
    fc 7.5
    ph 7.2
    ta 165
    ch 300
    cya 55
    what next?
    38,274
    What do you think is next? What has your reading taught you?
    Curious that your CYA is that high already? Did you add stabilizer separately? How many pucks did you use?
    DFW, TX
    24,485
    The most important thing is to keep your chlorine level above the minimum level for your CYA level on the Chlorine CYA Chart. Allowing FC to drop below the min will let algae start growing. The next most important is to keep your PH between 7.2 and 7.8. See links below on how to adjust it and what to adjust it to. We can work on TA and CH later.
    TFPC for Beginners
    Here are the Recommended Pool Chemicals to maintain your pool and how to add them.
    Oooops, sorry I interrupted the teachable moment!
    eazy's Avatar
    May 2015
    puyallup, wa
    11
    According to my reading, fc should be between 5 and 7. I am at 7.5 It seems a bit high, since it goes away on its own, this means I just won't add any bleach until it drops to 6.
    ph of 7.2 is on the low side should be 7.5-7.8. I need to read more and learn how to raise ph. I have "ez clor ph up" from the pool store before i use it again, I want to read and make sure it is what I should be using.
    I did add stabilizer separately on two occasions. I used 4 lbs total of "ez clor clor save stabilizer" from the pool store. On 5/15 and 5/16 2 lbs each time.
    Quote Originally Posted by pooldv View Post
    TFPC for Beginners
    Thanks for replying.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by eazy View Post
    According to Pool Math in a 4400 gallon pool 4 pounds of CYA will take you up to around 110. Way too much stabilizer added.
    Support the site
    38,274
    As long as the pH is in the 7s you are fine.
    You should stop using any solid chlorine as your CH and CYA are already getting up there. Stick with bleach.
    As pooldv said, the most important thing is to keep the FC above the minimum, there is no problem going above the target if needed. It is perfectly safe to swim all the way up to shock level FC.
    Looks like you are picking up on things pretty well
    Doh, just saw Tim's post ... that is not good.
    eazy's Avatar
    May 2015
    puyallup, wa
    11
    To raise the ph, should just get this 20 Mule TeamŽ Borax Natural Laundry Booster. and not use the pool store product I've already bought? Or can I use it till its gone store product is called ez clor ph up.
    38,274
    You can use that product if needed, although you may never need it.
    As Tim said, though, you may have added way too much CYA and need to replace half the water. The CYA may not show up on the test for up to a week.
    DFW, TX
    24,485
    You added 2 lbs of stabilizer Friday and 2 lbs Saturday in addition to using pucks with CYA? You might as well start the 50% drain and refill.
    eazy's Avatar
    May 2015
    puyallup, wa
    11
    I'll start the 50% drain and refill. Thanks for every-ones help.
    Less, pouring things in and more reading and asking questions here, not in the pool store going forward.
  20. Back To Top    #20
    38,274
    If you added everything you said you did, then I would expect the CYA to top out above 100ppm.
    You can certainly wait, but make sure you are keeping your FC high enough for the climbing CYA.
