Thread: How to repair red brick coping tiles
    Aug 2014
    Chalfont, PA
    8
    Hi All,
    We just opened our pool today and tiles are falling off and red coping tiles are chipped. I already purchased pool putty epoxy for underwater tile repair. Can anyone recommend ways to fixed chipped coping tiles? They are the typical red bullnose. I've attached an image:
    Wishman
    Inground 20k gallons plaster pool (2001) with Spa, Blue Haven 450 Cartridge Filter, Laars Lite 2 heater propane, Northstar 2hp pump, Dolphin Nautilus Robot Cleaner
    38,235
    Re: How to repair red brick coping tiles
    I would think you would have to find more tiles and chip out those and install the new ones. Although due to age, you would probably always be able to see the newer tiles.
    Afraid I do not really have any ideas beyond that.
    Aug 2014
    Chalfont, PA
    8
    Thanks Jason, I was afraid of that. I was hoping I could use some type of glue/filler.
    38,235
    You could try. Maybe a colored grout to try to match the brick colors. It would still likely noticeable, but at least no voids.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,797
    What it looks like to me is happening is that the pavers are shifting during the winter and where they push on the brick, they cause it to chip. The pavers should not have been installed directly up to the coping. There should have been a gap, usually 1/4" to a 1/2" where a foam backer rod is installed then special caulk goes on top of it. You will continue to have this problem if the decking (pavers) and coping remain in contact with one another. I'll leave it up to someone else to recommend how to create that joint now. I suppose you could pull up each paver and cut with a concrete saw then re-install.
    As for how to fix the brick coping...tough one.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Aug 2014
    Chalfont, PA
    8
    Thank you bmoreswim, that makes perfect sense. My kids were playing basketball and running back and forth hence cause the paver shift.
