Thread: High CYA after draining pool
    May 2015
    Austin Texas
    3
    This is my second post. I hijacked another post titled High CYA in new pool by albel1214. Sorry, didn't read enough of the rules, I'll try again.
    I drained my pool mid June last year because of high CYA and got it down to the 30-50 range (depending on who tested). I had no problems last year, water tested ok.
    Last month, started having algae control problems and FC staying high after shocking too long--the high CYA symptoms. Tested CYA 10 days ago and it was out of range. Took to Leslie's, they got 70 ppm, I know that was wrong. Took back two days ago and they got 120. I rigged a test today (didn't have the full amount) and got about 200 ppm (diluted sample read 100).
    People at Leslie's said I have build-up of CYA in my pipes and it leached back into the water after I refilled my pool. This doesn't seem right to me because testing look so good all last year through October. Has anyone hear of this build up?
    I want to drain again, but if there is build up, I'll beright back at the same place.
    13K in-ground gunite white plaster. Sta-Rite cartridge; Rainbow 320 chlorinater; Eclipse ozone generator.
    Polaris 280 with 1/2 hp booster. Main Sta-Rite Max-e-pro 1 hp. Taylor K-2006.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: High CYA after draining pool
    Quote Originally Posted by sjx View Post
    Welcome to TFP!!
    CYA doesn't build up in your pipes, it enters your water with every puck you put in your Rainbow 320 chlorinater. Each puck is almost half CYA
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Support the site
