Thread: Semi-inground pool flooring question
    May 2015
    Pittsburgh, pa
    3
    Question Semi-inground pool flooring question
    I have had numerous problems with my semi-inground pool that are mostly related to the pool supplier/installer. I have called and they are incredibly unhelpful and rude. My biggest complaint is the floor of my pool. I don't know anyone who has a pool like mine so I am not sure if it is normal or not. I have an Oasis 15'x24' pool. There are beams that run across the bottom of the pool. The sand on the bottom is incredibly uneven and the liner is "sucked" around these beams. At the junctions where some beams form a corner, there are divets that are about 1/2" deep. The beams are so prominent on the bottom of the pool you can literally trip on them if you are running around in the pool. Is this normal? Thanks for any input you can give me!
    Jul 2014
    Oakbank, Canada
    389
    Re: Semi-inground pool flooring question
    No, that is not normal. The installer did an improper job and it needs to be corrected. He is trying to bully you out of doing it right now, but he needs to held accountable and fix it right.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    May 2015
    Pittsburgh, pa
    3
    Thanks for the reply! I just don't want to seem like an idiot when I complain up the ladder if this is totally normal.
    Jul 2014
    Peoria, IL
    389
    I am not 100% sure how your pool is supposed to be but there is nothing about what you said that seems right. I would go as high up the ladder as you need to in order to get it fixed. Your liner is going to fail quite prematurely if it is that bad.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    May 2015
    Pittsburgh, pa
    3
    Do you think you should be able to feel the beams at all? Or that they should have leveled the sand to the top of the beam so it is all even?
    I should mention I plan on calling the pool manufacturer directly tomorrow to ask them the same thing. Just doing my homework about it first.
    Casey's Avatar
    SW PA
    10,423
    I would take pics of this and I'd do it at night with the water completely still with a pool light attached to the wall and lit. You may have to buy one but it'd be worth it for what it could show You and the installers. What this does is magnify every imperfection in the floor. It May be worse than you think.
