Thread: Very high ph water supply
    Apr 2013
    Argyle, TX
    77
    We will be putting up a 21' AGP soon and I know from the INTEX pools I have had before that my local (RURAL) water supply is well water.
    The PH was always very high and I need to know if there is any way to lower it when we fill the pool.
    The new pool will be approximately 11,000 gallons.
    Is there a safe way to add muriatic acid to a vinyl lined pool other than mixing a few cups at a time in a bucket full of water(Leslies Recommendation)
    21' NEW YORKER II 54" DEEP AGP Private Label MORADA RTR WILBAR Aluminum wall
    Hard Bottom and 1/4" Floor Pad 1/8" Wall Foam Well Water Perma 2500 Unibead liner King Technology Pool Chlorine Feeder HAYWARD Diver Dave cleaner
    Waterway 22″ Sand Filter 1.5 HP Center Discharge Pump Single speed Wide Mouth skimmer
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Re: Very high ph water supply
    Fixing pH while filling would be difficult. You'd need to know pH and TA - which is pretty easy - and you also need to know how much water is in there when you add acid. And within a few minutes of adding, the volume has changed already.
    Still, diluting the acid and dribbling it into the hose stream should get it mixed pretty good, and swishing it around immediately with the brush should get it spread out good. You probably also suffer from high Total Alkalinity, which is lowered by acid and aeration. That you can start on by setting the filler hose so it splashes into the pool. A garden sprinkler probably restricts the flow too much, but anything that really gets the surface churning good will do it.
    Adding muriatic acid is fairly easy when you have the pump running, pour slowly in front of the return jet while the pump is running. But adding acid before the pump is running can be problematic.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I would not worry too much about it during the fill process, just work on getting it balanced once the pool is full and you have the pump running.
    Apr 2013
    Argyle, TX
    77
    How much can safely be added at one time(Muriatic)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You can use the Pool Math calculator at the top of the page to find out. You enter your data, and it will tell you how much acid to add for a given pH decrease. You have to know a few fact.. Like the obvious, but also your TA (Total Alkalinity). Don't add and amount of Acid that will take your pH lower than 7.2 when you make an addition.
    You can pour in as much as needed provided you do it slowly. We don't suggest dilution first, but only because it creates another handling mishap potential. That said, many people do use dilution for adding acid.
    Essential Links:
