Results 1 to 8 of 8
Thread: Pump died
    May 2015
    Murphy NC
    3
    Pump died
    Opened pool, 30,000 gal salt water IG. One day in, pump starts smoking. New motor on its way. How can I maintain pool water til filter is up and running again. I put 2 sump pumps in to keep the water moving a bit but is there anything I can do to prevent algae bloom or whatever else.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Pump died
    Welcome to TFP! I am sorry your pump died. In addition to the sump pumps you can also brush and make sure you keep your FC up. What test kit do you have.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Pump died
    Keep the Chlorine up high enough for your CYA and keep the water well-mixed. Brush at least once a day. People have survived over a week with no algae bloom that way.
    May 2015
    Murphy NC
    3
    Re: Pump died
    Thanks for the advice. So far the water is still clear but I know that can change in a heartbeat.
    SunnyBama's Avatar
    Feb 2015
    Birmingham, Alabama
    21
    Re: Pump died
    I just had a similar situation; my pump was off for 3 days from a power outage. I brushed the pool once or twice a day to circulate the water and tested FC to make sure it stayed at an appropriate level. I only had to add bleach once. Also use a leaf rake to get debris out of the water.
    Intex Ultra Frame 20'x52" pool (10,600 gallons); Sand filter (Model SF80110); Krystal Clear SWG (Model CS8110); AquaBot PoolRover Jr. Pool Cleaner; TF-100 Test Kit with SpeedStir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,461
    Re: Pump died
    Quote Originally Posted by Treowe View Post
    Welcome to TFP!
    The most important part is to keep your chlorine level above the minimum level for your CYA level on the Chlorine CYA Chart. Allowing FC to drop below the min will let algae start growing.
    Here are some intro Pool School articles to read
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals to maintain your pool and how to add them.
    Use PoolMath to figure out how much to add.
    May 2015
    Murphy NC
    3
    Re: Pump died
    Well, the good news is the new pump arrived today, the bad news is the frame size is wrong.
    DFW, TX
    24,461
    Re: Pump died
    Dangit!
