Results 1 to 11 of 11
Thread: Need specifications on pool filter sand.
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Hi all, just bought a Pentair TA60 Clearpro sand filter and would like to know what specifications I am looking for on pool filter sand... I have combed the manual, I have done a lot of research, not finding anything real definitive. Not interested in the zeolite sand. There's quickcreate, HTH, others, what spec should I look for on the label to get quality sand for my filter?
    Thanks
    Owner since August 2014. 21,500G Liner In ground Pool with attached 600G plaster in ground hottub. TF-100 Test Kit, Filter: Pentair TA60D Clearpro Sand (HTH) Filter. Pool: 1 Drain, 2 Skimmers 4 Returns. Hot Tub: 1 drain, 1 skimmer, 2 returns. Hot Tub/Pool run by Sta-Rite Dura Glas Single Speed 1.5hp P2RA5F-182L pump with Emerson K63CXESE4972 motor. Spa jets run by Sta-Rite Dura Glas H/L model number unknown.
    Re: Need specifications on pool filter sand.
    Anything labeled as pool filter sand should work. Technically you want #20 grade silica sand.
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Quote Originally Posted by JasonLion View Post
    Thanks, that's what I needed, I remember seeing the #20 before in other posts, but was not sure if it was 20# as if someone was talking about the 20 lb bag they got.
    What brand would have that spec?... don't want to run to HD or lowes and end up going somewhere else.
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    For what it is worth to anyone...This is what i have found. Review the following link to understand what #20 is...
    http://www.azom.com/article.aspx?ArticleID=1417
    When Quikrete says their sand is Sieve size 20-40... http://www.quikrete.com/PDFs/DATA_SH...PoolFilter.pdf
    that means that their sand has been sifted anywhere between 40 and 20... #40 is smaller particles than #20.
    So if it is bad to have the smaller #40 sand particles then you would not want quikrete. If it is ok to have that smaller size, then go nuts...
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Quote Originally Posted by caliskier View Post
    Any thoughts here, I actually created a question for myself with that research...If I use a mix like quikcret that has from #20 down to the smaller #40 sand, is that too small? is the Spec only #20 and no smaller?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Yes, the laterals inside the filter will stop #20 sand but anything smaller will slip past and end up in the pool. Look at the sixth picture in this thread.
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    good point, what about the clearpro from Pentair style laterals that are supposed to filter finer particals... will they just clog with #40?
    http://www.amazon.com/Pentair-150088...earpro+lateral
    expensive little sucker, but that is what i have.
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    here is what i am thinking... if i get this sand, wit these laterals, it will filter better. my logic is the finner grains (#40) will catch the smaller stuff but not go into the pool because these laterals have smaller openings. is my logic in error?
    Richard320's Avatar
    Jan 2010
    19,074
    I don't know.
    I'd be afraid the finer sand would pack too tightly and restrict water flow.
    And if it does turn out to be too fine, it will all end up in your pool.
    I nominate you to experiment and find out and add to the general store of knowledge here.
    As it is, a sand filter with #20 sand will filter out stuff too fine to see with the naked eye. As long as you maintain the water chemistry, a sand filter is more than sufficient. If you want it super filtered, add a little DE to the filter. It forms a fine layer on top. Like setting window screen on top of a barbeque grill.
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Yeah... I hear you about it packing tightly. I opened the box tonight and the Spec says:
    0.018-0.022in or .44-.55mm #20 Standard Silica Sand having a uniformity coefficient of 1.75 or less.
    Maybe I don't need to test it, here is a review i found about the HTH brand at Ace (review says generic aqua quartz for some reason)... NOTE #1153 is the quikcrete stuff...
    Comments about GENERAC Aqua Quartz® 50lbs Pool Filter Sand (61308):
    Tried another brand "Pool Filter Sand" (#1153) when I got the filter last year. It was terrible. There was no consistancy to the size and much of it was too fine. Caused too much back pressure even after cleaning. Limped through the last summer & dumped it out at season end. Put this sand in after a complete tear down & cleaning of the system (it was obvious the grading was consistant & the proper size). It was amazing how much better the system performed. Back pressure where it should be, cleaning cycle fast, able to use the vacuum with it (couldn't use with the other sand). Over all, exactly what it was supposed to be. Great product.
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    I loaded it with HTH sand... i really hope it is good sand, i thought it was until my wife brought it home. I had a bag of leslie's from a long time ago for my aquarium, so i used both. I noticed that the HTH was not uniform in size at all, big and small grains. The leslie's was much finer and uniform in size. If I have problems with it I will come back here and post results, if it is awesome I will post that too.
