Thread: Polaris stops pumping after 1.5 minutes.
    May 2015
    Sharpsburg, ga
    2
    Polaris pump shutting down after about 1.5 minutes
    We purchased a new Polaris last summer. This summer when running the Polaris the pump started shutting off after about 1.5 minutes. We had never replaced the pump so we purchased a new PB4-60 pump. It continues to do the same thing. There are no air bubbles present in the water flow back into the pool. Any idea what could be the problem?
    20 x 40 inground. 3.5 shallow and 8.5 deep end. Liner. Hayward DE filter.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Polaris stops pumping after 1.5 minutes.
    Is this on a timer or control system?
    Does it shut off if the Polaris is disconnected?
    May 2015
    Sharpsburg, ga
    2
    Quote Originally Posted by JohnT View Post
    The Polaris is not on a timer or control system. When the pump is run without the Polaris hooked up it still shuts off. This is also with the new booster pump.
    SW Indiana
    9,198
    Well, it would seem like the options are that it is overheating because of a lack of inlet water or a power problem. You seem to have good water flow, so I think the next step should be to verify the input voltage when the pump is running and when it shuts off.
