Thread: Need help with leveling... first time pool owner needs help bad!
    Just got an intex metal frame pool 18 x 42in. We put the pool on a site that had a 13 in slope that was filled with sand, now our pool, that is filled halfway up with water is sinking.
    We used the sand because that is the same site where we were going to put up a 24 ft used pool last year, but was not in the best of condition so we couldn't. We figured since the sand had been there a year the intex pool would be fine. But as i mentioned above it is sinking.
    We are in the process of draining the pool and were wondering if anyone had some advice for us on how to level this ground.
    Do we need to remove all the sand?
    Do we need to put something under the posts to help from sinking?
    What is the best way to level without heavy machinery?
    And any other advice that you can come up with would be very helpful.
    Thanks and have a wonderful day!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Need help with leveling... first time pool owner needs help bad!
    Quote Originally Posted by tlmiller1987 View Post
    Welcome to TFP! As for leveling we used a gravel rake on the smooth side then used a grass roller you fill with water to help compact it a little. Some people who deal with slopes also add a 2x4 frame around the border of the sand to keep it from shifting.
    You definitely need to put pavers under the leg posts or it will just continue to sink.
    16x16 pavers should be perfect. Make them level with the top of the sand.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    This is one of the better threads on levelling. Lots of pictures on page 2.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,579
    Dig down to level. Do not add sand/dirt to bring it up. It will sink not mater what you put under the legs. Yeah it is a lot more work but.......it is MUCH safer.
    Kim
