Thread: Crack in tile and below
    May 2015
    WI
    3
    Vinyl pool 18x36 25k gallon Wisconsin
    Noticed some hairline cracks that go from the tile area to just below the water line. Any suggestions, just possibly try to fill a bit with silicone or this may be more serious?
    Pool was built in 1984. Liner was replaced about 13 years ago and does not go all the way up to top of pool, liner goes up to only a certain point as you can see in the 2nd picture.
    Thanks
    Jenny
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Crack in tile and below
    Looks like your liner is getting brittle and I would be surprised if you're not losing water already or getting water behind the liner. 13 years is quite a long time for a liner. Start pricing out (and saving for) a replacement liner.
    Any water loss?
    Isolated Spa - 345 Gallons
    May 2015
    WI
    3
    Quote Originally Posted by JVTrain View Post
    Any water loss?
    Just curious to know, were you able to tell from the picture the liner is getting brittle or just because its so old?
    When a liner gets replaced its just the vinyl portion correct, not that area of my pool that has that tile and I guess thats the white plaster thats between the liner and tile?
    I havent done a bucket test yet. Last year I noticed maybe a little bit of a loss but with a new filter, it all seemed ok.
    Thank you for the reply
    Jenny
