Results 1 to 7 of 7
Thread: Vacuum for sand filter?
    Hey guys. I've got one of those Intex Ultra Frame Pools (Walmart). I also got the 2650 Intex sand filter because the cartridge filter was junk. I've tried a couple of different vacuum methods. The garden hose attachment vacuum sucks (not in a good way). I got this http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    kit, which comes with a small hose (1.25" I think). The problem is, that even when I just thread that little adapter:
    onto the intake, the pressure in my on my filter drops to nothing. I think that adapter creates too small of an intake. Is there a full sized hose that I can get that threads onto my intake? I've seen some 1.5" hoses, but they have straight, smooth ends, not threaded.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Vacuum for sand filter?
    The pressure will drop no matter what. I lose at least 5 psi when I vacuum, because the hose is smaller than the rest of the plumbing and it's a lot longer run on the suction side.
    The big question is: did it vacuum up what you wanted it to vacuum up? If it did, just use it. Once things go back to normal, the pressure should too. It might go higher, because there's stuff you vacuumed up clogging the filter.
    Oh - one last thing... did you fill the hose with water before connecting it? Hooking an empty hpse to the pump inlet will cause it to lose prime and pressure will go to nothing. So will flow. I just set my vacuum in the pool and feed the hose straight down so any air io it escapes out the top. When it's full, I connect it.
    That's the thing. Even just putting the adapter on makes the pressure drop to pretty much 0.
    BUMP
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    Even with the aid of the pump, you still need to create a siphon with the hose as you attach the vacuum to your skimmer basket(?).
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    Sorry, wasn't clear. So, even when I just thread that adapter on (the one in the pic) to the intake (I have no skimmer) with NO hose attached, the pump pressure drops to 0.
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by jephph View Post
    There's no casting flash inside or something? That shouldn't happen. Period.
