Thread: Chorine / CYA chart
    Apr 2015
    Boardman oh
    21
    Chorine / CYA chart
    Hi! I'm reviewing the chart for the correct shock level but I don't know what the numbers mean...is it gallons?
    OHpool
    27,300 gallon IG vinyl liner
    Hayward GM 245 sand filter
    Taylor complete FAS-DPD K-2006 test kit
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Chorine / CYA chart
    ppm.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Apr 2015
    Boardman oh
    21
    Thank you!!
    OHpool
    38,463
    Check out PoolMath as well. It will do the calculations for you. There are instructions at a link at the top of it.
    Please add your pool details to your signature as described HERE as it will help us help you.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,506
    Welcome to TFP! Good job checking out that chart!
    Here are some intro Pool School articles to read next.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals
    Use PoolMath to figure out how much to add.
