Thread: Levels to high
    May 2015
    rockford,il
    5
    Levels to high
    We are new pool owners and just started opening the pool for summer. We shocked it last night with a liquid shock that included algaecide and chlorine and I just tested it today and the test strips are saying
    PH 8.4
    Free chlorine 0
    Total alkalinity 240
    Stabalizer 300
    All obviously to high except the chlorine. How do I fix this?
    38,305
    Re: Levels to high
    Well, you need to throw away the test strips and invest in one of the Recommended Test Kits so we can offer advice based on reliable test results.
    Have you discovered Pool School yet? Start with these so we can speak the same language:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    How does the water look?
    We do not recommend the use of algaecides, etc.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Levels to high
    Welcome to TFP!
    Here are the Recommended Levels for your pool. And use PoolMath to calculate how much to add to achieve those levels.
