Thread: Should my SWG turn on/off with pump?
    Apr 2015
    Arlington, TX
    7
    Got a breeze 340 installed last week. Noticed yesterday. The unit doesn't turn on or off with the pool pump. Should it? If so what could the problem be?
    38,237
    Re: Should my SWG turn on/off with pump?
    I am not familiar with that system. Usually you want the SWG to be powered off the same timer as the pump.
    Please add your pool details to your signature as described HERE as it will help us help you.
    Dec 2014
    Rockville, MD
    78
    If you turn off the circuit breaker to the pool pump, does the SWG turn off? If it does, it seems like the SWG is attached in parallel with the pump at the breaker or attached to the line screws of your timer instead of the load screws. SWGs are meant to be powered only while the pump is powered. While the flow switch for the cell is preventing it from generating chlorine when it shouldn't, you might get longer life from your controller if you attach it so it only turns on while the pump is running.
    Pool: 40x15ft "Mt. Lake" shaped plaster IG (30k gallons with Borates)
    SWG: Circupool Si-45
    Pumps: Hayward MaxFlo VS (SP2302VSP) + Booster Pump for Polaris 180
    Robot: Kreepy Krauly 830 || Filter: Pentair Tagelus TA-60D (Sand)
    Test Kit: TF-100 (with Speed Stir)
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    it should be wired the same as the pump .. is this the system you have?
    http://www.amazon.com/Breeze-320-Sal.../dp/B009I5KX2I
    need to make sure it is wired to the timer of the pump..
    Apr 2015
    Arlington, TX
    7
    Actually this is the system. http://www.amazon.com/SGS-Breeze-540...CTR9M33BDQRWZB
    It is wire to the pump timer switch. He must have put it on a constant power lead. I will take a pic when i get home.
    Apr 2015
    Arlington, TX
    7
    Looks like he has the hot going to a line...
    The white wire coming out of the black cable to the left is the SWG cable
