Thread: Savi Melody: transformer to powerful? Adding resistance?
    Jun 2014
    Montreal QC Canada
    16
    My single underwater light (Savi Melody) blinks if light more than 15 minutes. Tech support tells me it's because my transformer is sending too much wattage.
    I'm getting 12.7 Vac at the transformer (100W Intermatic) and the light is approximately 40' away. According to the manual 12.4 would be the maximum. How would one add a resistance to lower the wattage?
    Many thanks
    2650 gal (10k litres) IG Fibro F20 Fiberglass, 1 HP Hayward SuperPump, Hayward Pro series top mount filter (glass filled), Pentair intellichlor
    Salt Chlorine Generator, Savi Melodi LED light (1), Bowman CN-200P Cupro-Nickel Heat Exchangers (plumbed to domestic natural gas hot water tank)
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Savi Melody: transformer to powerful? Adding resistance?
    Hello,
    Here's the link to the manual: https://www.1000bulbs.com/pdf/interm...structions.pdf
    I think there's a 12 and a 13 volt output option. Sounds like you may be tied into the 13 volt tap. Try the other one. There should be a wiring diagram on the inside.
    Jun 2014
    Montreal QC Canada
    16
    No, the 13v (yellow) wire is capped... Thanks for the manual.
