Results 1 to 9 of 9
Thread: Do I need to SLAM?
    May 2015
    River Falls, WI
    124
    Do I need to SLAM?
    This is the first time I've tested a positive for CC’s in my pool. Here are the numbers:
    FC 7
    CC.5
    PH 7.4
    TA 130-140
    CYA 30 - still creeping this number up after my partial drain/refill last week
    We were gone most of Saturday all of Sunday so early Saturday morning I tested FC's at 4 and figured that I would just double the amount to ensure it held until Monday morning. The FC's did hold. I expected a bigger drop…
    We did have storms and while the water is sparkling and clear there is a lot of debris in the pool. I’m going to be cleaning it soon.
    I’m thinking the presence of junk on the bottom of the pool is contributing to the presence of CC’s? If I clean the pool do I still need to do a SLAM?
    In the future, is it best to take readings sans debris?
    ~19k Gal, IG Vinyl, Hayward SP2607X10 1hp pump, Hayward S200 Sand Filter, built in 70s, has 8 deep end with diving board, 1 skimmer, 1 return, 1 low hole, Polaris booster pump PB4-60, old Polaris robot not sure model, Rheem P-M266A-EN-C 266,000 BTU heater, solar cover, Taylor K-2006 test kit, Speedstir
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Do I need to SLAM?
    As long as your water is clear I don't see any reason for you to SLAM. Your numbers look good. I had one day my CC went to.5 also, but it was gone the next day after brushing, vacuuming and running the filter.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Nope. Just vacuum up the debris and empty the baskets and carry on normally.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Clean it, circulate it, retest it.....then decide. Should be an easy one.
    May 2015
    River Falls, WI
    124
    Good idea. Plus, retesting will give me a reason to try out the sample sizer and speed stir that just arrived!
    Fleck's Avatar
    Mar 2015
    Jacksonville, FL
    37
    Quote Originally Posted by wrems View Post
    I'm jealous.
    AG 18k gal 28' circular pine straw collector, Hayward S220T, Power-Flo Matrix 1.5 HP
    Zodiac Ranger cleaner w/ Twister and a PoolSkim
    12" red, green, yellow, and white beach ball
    K-2006
    May 2015
    River Falls, WI
    124
    I cleaned the pool a bunch today. So much crud... It's much cleaner but still not perfect. I tested again for curiosities sake and got:
    FC 5.5
    CC .5
    I'll keep a close eye again tomorrow and do some more cleaning.
    Apr 2010
    East Texas
    9,572
    Trust me-----------------.5 is close enough to perfect!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    We will accept nothing less than perfection!
