Thread: Non stabilized puck for auto chlorinator?
    May 2015
    Fredericton, nb
    3
    Relatively new pool owner here. I see HTH makes a non stabilized puck, why is it I can't use that in an auto chlorinator and avoid growing CYA problems?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    Re: Non stabilized puck for auto chlorinator?
    If it is a CalHypo puck it melts much too quickly to use in an auto chlorinator.
    Support the site
    Jul 2014
    Peoria, IL
    389
    As long as the tabs are just chlorine, I see no problem. Just watch the list of ingredients and know what you are putting in your pool.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    May 2014
    Franklin, NC
    9,196
    Quote Originally Posted by bdex View Post
    there are no "just chlorine" tabs. The chlorine needs something to bind to to stabilize it. CYA, calcium and lithium are the three things you will find in solid forms of chlorine.
    Support the site
    Jul 2014
    Peoria, IL
    389
    Quote Originally Posted by tim5055 View Post
    Very true.
    I cannot easily find good info on the hth tabs in question. Again, know what you are adding to your pool. If you have low calcium fill water and are constantly adding calcium chloride and that is what is in the tabs, could help. Just be careful and keep a close eye on your test results. How are you testing your water?
    The general consensus is going to be SWG or LC.
    Central Illinois
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Folks, I'm closing this thread to draw attention to a potentially very dangerous situation.
    Putting cal hypo pucks into a chlorinator that has been used for trichlor pucks is a huge problem.
    It can cause the chlorinator to explode. You should never mix chlorine types, and that includes using a different type of chlorine in a chlorinator.
