Thread: Question on CYA/Bleach level
    Mar 2013
    CT
    351
    This has always sort of confused me...
    My CYA is at 40. Target chlorine level for that CYA reading is 5.
    So when I am done adding my bleach - what should my chlorine level be?
    I should shoot for MORE than 5 no? Or do I just try and get to a level where when I do my next test it's not below the minimum for that CYA reading?
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,633
    Re: Question on CYA/Bleach level
    Ummmmmmm.....5? You may have to go higher than 5 depending how much FC your pool loses on an average day. Normal FC loss is between 2 and 4.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Minimum is 3, Target is 5. Shoot for 5. The next day, if you're at 3 or above, shoot for 5 again. If you consistently come up below 3, say 2, then you'll want to target 6, so the next day you never drop below 3.
    The Target is just a ballpark estimate. The minimum is absolute. Every pool is slightly different. Adjust your target so you never drop below minimum and you're golden, no matter if that target is 4, 5, 6, or 7. If you're losing more than 4 FC per day and you can't blame it on a massive swim party, something else is going on.
    Mar 2013
    CT
    351
    "Adjust your target so you never drop below minimum and you're golden, no matter if that target is 4, 5, 6, or 7."
    Perfect!! Thanks Richard!!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    +1 to that. This chart, Chlorine CYA Chart
