Thread: review of CircuPool SJ-45
    Apr 2015
    china grove,nc
    71
    I was in the market for a swg that would work well for my ig 21000 gallon pool, did a lot of research and found tfp in the process of all the research. my local pool store pushed the Hayward model at a price tag of $1200.00, they didn't seem to offer much guidance or customer support with the unit in general, just told me everyone loves them and they are $$$ and would have to replace the cell every three years for $700.00. I ended up finding a post on here with someone asking what was the best budget swg, and then I found the cirupool series and others. I had it all narrowed down to three models.. circupool sj-45, circupool si-45+ , and the Hayward t15 model, after more research and calling discountsaltpool several times I was talked into the sj45 model, so here is my review of it.
    install
    install was straight forward and easy to do, I am sure most the models are just as easy, the difference being that the sj model mounts with the flow and return from the bottom instead of inline
    no flow sensor to install as I was told it was made into the cell, so that less fittings to install or mess with which is a plus
    cell housing is clear for easy inspections of the cell itself
    performance
    one of the reason I choose it over the Hayward was that it was rated for 2.0lbs cl a day
    led lights for display
    clear cell housing to see it working
    so the cons
    there is much info for the unit itself
    doesn't give any read outs
    only has 25% 50% 75% 100% and super cl
    overall I like everything but the end user not being able to fine adjust the output, if I had to do it again I would be up in the air on a unit that had more features then this one, overall its a great unit just missing features I believe would be nice to have
    sj45 swg, tf-100 test kit, 16x32 ig 22,000 gal vinyl, Dolphin nautilus plus
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Re: review of CircuPool SJ-45
    The cons you list are amount the reasons I chose the Circupool SI-30 Plus. I like to see the readings and be able to adjust the output in 1% increments. It does not have a "clear" cell so I have to remove it to inspect it but, like your cell, I'd have to remove it anyway if it needs cleaning. Another plus for me is has an extended life cell.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    laveenmoose's Avatar
    May 2012
    Laveen (Phoenix), AZ
    41
    You can download the user manual here if you don't already have a copy. whenever I've had a tech question, I've always found Discount Salt Pool's support to be excellent, and soon had the control unit figured out.
    10.5K IG gunnite pool with micro-pebble finish in Caribbean blue with Baja step. Haywood main filter with Perry's Pool Pump 1hp motor. Jandy CL-340 cartridge filter. Circupool RJ30 SWG system. TF100 test kit with Speedstir. Floating beer cooler.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    My RJ60 you can adjust the clorine level in 10% increments.
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
