Thread: Filter grid issue ??? (If it isn't one thing it's another)
    Hello all,
    Jeez I can't seem to catch a break this season
    The skimmers have finally been re-plumbed so I started focusing of getting my pool chemically balanced. The water is very cloudy at the deep end so my thought was I must be low on something, I was at "0" for CYA and TA. I added the baking soda and granular stabilizer, the baking soda was pre-mixed in a bucket and added directly to the pool. I added the stabilizer directly to the skimmers, I know there is a controversy on whether to add to skimmer or use the sock method but I went with the skimmer and saw this:
    One minute, I can't upload the picture from my computer.
    Please look at the pics in the response below, That is what I am seeing.
    Fatcat07, In ground pool, Vinyl Liner, 18 X 36 Pool size, 30,000 Gallons
    Hayward Heat Pump - Hayward HeatPro Heat Pump
    Hayward Filter DE2420 - 24 sq ft (I think)
    Hayward pump - Not sure of the model number
    Suffolk, long Island
    Re: Filter grid issue ??? (If it isn't one thing it's another)
    Does this mean my filter is busted ? My PSI starts at 15 and in time it does raise to 20. I also see the D.E. exiting the returns when I add it to the skimmers.
    Hello all,
    I will go home and inspect the grids, if I find the tear 3 questions:
    1. Can it be repaired ?
    2. If not and I do find the grid that is torn am I better of just replacing the 1 grid or replacing the whole set ?
    3. Is this the correct D.E. grid for my filter:
    Filter Grids De-Grid Pack 12In 24 Sq Ft
    SKU:
    PPOLFS2002
    Thanks
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Adding the CYA to the grids probably did them in. Never add any chems to the skimmer if you have a DE filter since you can ruin parts of the filter.
    I've always replaced the entire grid assembly, but I know others will just replace the grids. Replacing the grids can be pain and I would rather be lazy and buy it pre-assembled.
    I have no idea on whether that is the correct part. FYI, SKUs are #s created by the seller and isn't the part # given by the manufacturer. You should pull up the manual and it will give you a part # and you can compare that to the part # listed by the seller.
    Make sure that whatever you order replaces all of the grids since most DE filters have grids with multiple sized grids in one filter.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
