Results 1 to 7 of 7
Thread: Pool Wall / Liner Help
    Sep 2014
    Oceanside NY
    9
    Hi all,
    I recently purchased a 12X20 oval pool and had a professional company install it for me last summer 2 feet below ground. I noticed this year that I can see the imprint of bolts on 2 of the wall joints on each side of the skimmer. There are no punctures in the liner yet but I am nervous about this. I would say they come out about 1 cm. I am wondering what could have caused this. Maybe a shift in the pool as it settled? The bigger question is what happens if the liner breaks? Can some please help this new pool owner. Thanks in advance!
    12X20 semi inground pool with SWG; 1.5 HP pump and Cartridge filter; 5600 gallons
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    Re: Pool Wall / Liner Help
    I can see imprints in mine also at the skimmer wall. Have no idea if this is normal, so I'm hoping someone will come along and provide some insight!
    ​Jennifer
    19k gal, 27' x 54" AG Aqua Leader Saltwater 8000 installed April 2014; Aqua Pro 19" Sand Filter System 1.5-hp Pump; Hayward Aqua Trol Salt Chlorine Generator System; Overlap Boulder Swirl Liner; Polaris 65 Turbo Turtle Automatic Cleaner; TF-100 Testing Kit
    Sep 2014
    Oceanside NY
    9
    April's Avatar
    Apr 2014
    KY
    138
    I don't know if it's normal but mine looks the same way. Pool has been up 4 years and I haven't had a problem yet.
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    Casey's Avatar
    SW PA
    10,444
    It's normal. Those are wall bolts. There is no way to get around them. Your installer should have used duct tape over them to protect your liner. It is perfectly fine.
    Sep 2014
    Oceanside NY
    9
    Thanks, Casey! I was very nervous but glad to hear it sounds pretty common. I just found it odd that I only recently noticed them and my pool was installed late last summer.
    Casey's Avatar
    SW PA
    10,444
    All above ground pools have them.
