Results 1 to 11 of 11
Thread: Does Plumbing Look Correct?? Have Pics
    Apr 2015
    Wheatfield, IN
    53
    Does my first attempt at plumbing these items look correct. Everything is dry fit right now. I know I need to complete the suction side but need another 3 way valve which I ordered this morning. Does it matter that the first three way valve after the salt is turned and not utilizing the side that is stamped "Inlet" ?
    thanks
    Attachment 36582
    Re: Does Plumbing Look Correct?? Have Pics
    There are several things that could be improved, though I don't think that any of them are critical.
    It is better to have some straight pipe in front of the pump before the 90.
    It is better to have the input to both of the three way valves come in the center port, rather than one of the side ports.
    The white sweep 90s do not appear to be schedule 40. You want all of the plumbing fittings to be schedule 40.
    I am assuming the black fittings are CPVC. You want CPVC on the pump outlet and both the heater inlet and outlet.
    There are significant advantages to having a couple of inches of straight pipe between things. That gives you places to cut the pipe and make changes in the future.
    It is best if the SWG is several inches above the heater outlet. You can do that with the existing setup, just slope the straight section of pipe after the heater up a little.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Use unions where things may have to come apart in the future.
    Make sure you have room to move around in the back of things.
    If you put a T instead of a 90 at the pump outlet, you can then install a threaded bushing and a hose bib in the extra leg in case you need to lower the water level after a massive downpour or for winterizing.
    If one of those 3ways after the SWG feeds a spa, you don't want the SWG before it. You'll overchlorinate it in spa mode.
    That's all that springs to mind based on my own setup's shortcomings.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Like Jason said all those sweep curve fittings look like DWV drain pipe, not Schedule 40 pressure pipe, you can tell by the half length glue fittings. You can probably get away with DWV pipe fittings as long as they are above ground. My pool was plumbed with them and 4 times in the last 10 years I had to cut up the concrete to get to and fix a leak caused by the use of the wrong type elbow fitting when the pool was built.
    Apr 2015
    Wheatfield, IN
    53
    I beleive they are all sch 40 fittings? I should have bought street fittings, (one with a male end and the other end a female) but I ended up buying a box of these instead. The schedule 40 2'' pipe I am using fits perfect. MAybe I am confused? Also do I need any check valves?
    thanks guys
    Do I need to slope my return and drain lines for winterizing? How deep do my plumbing lines need installed? My pool installer said that I do not lower the water level when winterizing something to do with my automatic cover needs the water for support? But wont the returns and skimmer freeze? confused
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    On a chlorine tablet chlorinator setup you need a check valve between the heater and chlorinator. Not sure with the salt water variety.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by 71CHEVY4X4 View Post
    thanks guys
    Those are DWV fittings and not designed for pressurized systems. The short bonding area for the solvent weld is the key difference.
    Apr 2015
    Wheatfield, IN
    53
    I see. I will get different ones from Menards or Lowes if they have them. So use nothing with DWV labeled on it???
    The 10' sticks of PVC say DWV on them is that OK to use ??? The pipe is schedule 40 it is made by Charlotte Pipe True Fit 7200 2" PVC type 1 schedule 40 NSF DWV ASTM D 2665
    Isaac-1's Avatar
    SW Louisiana
    6,711
    the 10' sticks at Lowes are dual rated DWV / Schedule 40 so are fine, it is just those DWV fittings with short glue joints that are the problem.
    Apr 2015
    Wheatfield, IN
    53
    What type of glue? Medium set PVC glue?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    medium set PVC is good for all the white joints, not sure what the others are, I usually use blue rain or shine, but medium set is a little easier to work with and is clear
