Thread: Chemical storage
    May 2015
    Monroe/NJ
    76
    Chemical storage
    Hi I have a very basic question. Can I store my pool chemicals outside in the shed or is there any concern of heat making any of the chemicals unstable or breaking them down? Thanks. Specifically liquid bleach, Borax, Armand Hammer baking soda, muriatic acid, calcium hardness, CYA.
    Inground Pool Completed April 2015
    Salt Water Generator- Nature 2 Fusion Soft
    33,500 gallons, Gunite/White Plaster
    Cartridge Filtration
    Heat Pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Chemical storage
    You want to store Bleach where it's cool and dark. Keep things that would react away from each other should they spill. If you have Metal stuff in there you don't want to be corroded more quickly, I would suggest somewhere else. Acid in particular. It vents, as does bleach and if tools are pretty close, you will see them rusting much more quickly.
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    HEAT and sunlight are HUGE enemies of chlorine. Not a good idea to store your MA close to the chlorine or anything metal due to out gassing either btw.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Dittos to what both these guys are telling you. I keep MA in an enclosed but vented container that sits outside in a shaded area. Used to keep it in the garage. Learned that lesson soon after joining TFP and connected the dots as to why nearby metals began to rust for what I (incorrectly) thought was no apparent reason. Bleach stays in my utility room. Also, while I always keep an ample supply of bleach around since I go through that much quicker than MA, MA is the one chemical that I do not "stock-up" on. I buy it in as small a quantity as I can. I see no need to keep any more of that stuff around than I need to.
    May 2015
    Monroe/NJ
    76
    Thanks all-
    So right now I have the room to keep the MA in a new shed by itself- I have to stock up for now as I have a new plaster pool that is constantly demanding acid.
    If I keep that in the shed by itself, any concerns with the heat in the shed causing problems?
    Heat Pump
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Basic chemical safety, keep acids and oxidizers seperate. Vigorous reactions when they are mixed! Also keep both away from fuel (portable gas cans).
    As noted above, keep chlorine as cool and dark as possible, and keep different forms of chlorine seperate (i.e., trichlor and cal-hypo). They don't play well when mixed, very energetic reactions.
    Muriatic (hydrochloric) acid is very stable over a wide range of temeratures. You can keep that outside. I buy one gallon at a time and keep that in a white 5 gallon bucket with a lid. I also keep the measuring cup inside the bucket. The lid keeps what little fumes that make it past the cap contained. Here's how it looks (appropriate hazmat placard optional )
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
