Thread: Silica sand #20
    May 2015
    york pa
    1
    Silica sand #20
    I bought a new intex pool,recommended i use silica #20 sand ,i can not find tje sand anywhere ! Anyone know where to buy the sand?
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: Silica sand #20
    Check with a local concrete or masonry supply company. They usually have a selection of different grades of sand. Also many home improvement stores and, of course pool stores are a good source.
    Edit: Will also be known as #20 Quartz filter sand
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Silica sand #20
    Lowes, home depot, pool store all should have #20 sand.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Silica sand #20
    Ace Hardware store
    Orlando, FL
    690
    Re: Silica sand #20
    Check the garden center at Home Depot where the pool supplies are stored.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    May 2015
    Hampstead, NC
    18
    Re: Silica sand #20
    Quote Originally Posted by robandreani View Post
    I shopped around this week for silica sand. My local Wal-mart didnt carry it, only paver sand.
    I checked Lowe's and the only thing they had were 25# boxes of silica sand and they were like $25 each. No thank you.
    I went to Home Depot and they carry quickcrete brand pool sand 50# bag for like $5.47
    Thats what I got and it seems to be working fine.
    Intex 18X52 Ultra Frame with Sand filter
