Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: 1st results with SWG running
    Aug 2014
    East Northport, NY
    155
    Hi.
    Looking to get feedback and where/what to add first. SWG has 3100 PPM and I have been running it manually until I get it integrated with the pump for around 5 hrs at a level of 45%. So I appreciate any input.
    FC - 5
    CC - 0
    TA - 100
    CYA - 30
    THANKS
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: 1st results with SWG running
    Hi Amanda,
    you didnt list the pH.
    As for the other readings, you may want to bump up your CYA to 40-50, but thats all you need to do.
    TA will take care of itself.
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Here is the Water Balance for a SWCG pool
    The two most important things are to keep the chlorine level above the minimum level for your CYA so algae doesn't grow, Chlorine CYA Chart, and to keep your ph between 7.2 and 7.8.
    Aug 2014
    East Northport, NY
    155
    Ok so I am going to buy some borax later and add. Ph is a little low when I do the phenol test. Not sure how much I should buy but I will start with a few boxes and add 1 and test.
    TF-100 Test Kit
    Aquabot Bravo
    Aug 2014
    East Northport, NY
    155
    In efforts to raise CYA - Can I use this?'
    Before I found this great place, like many others I have amassed many chemicals in my shed. To that end I am in need of raising my cya and I have these blue pucks that I got from the pool store last year and they are supposed to be for stabilization. Do you think I can put them in a sock in my skimmer? Or do they have a shelf life. If not any feedback on brand or where to purchase products?
    Thanks
    TF-100 Test Kit
    Aquabot Bravo
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: In efforts to raise CYA - Can I use this?'
    Depends what's in those "blue" pucks. If they are trichlor pucks, save them for vacation and weekends away this summer. Read label carefully! Easier and quicker just to get some plain old stabilizer from Walmart which is pure, granulated, and dissolves easily in a skimmer in a sock or pantyhose.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    To add to what woodyp said, if they have any metal at all listed on the ingredients, do not use them. They'll lead to staining, green hair etc. If there is any mention of copper, silver... don't use them. Try to return unopened containers for store credit if they do contain metals, maybe get yourself some muriatic acid or liquid pool shock/bleach in exchange. Open containers, you're best bet is to donate/drop them off at nearby HHW (household hazardous waste) drop off site, if they contain metals.
    If they do not contain metals, you can use them to add CYA intentionally or during vacation.
    Isolated Spa - 345 Gallons
    Aug 2014
    East Northport, NY
    155
    Well seeing I am going to walmart for borax I can pick up stabilizer also but I will check to see if I still hve the info on the pucks.
    TF-100 Test Kit
    Aquabot Bravo
    Aug 2014
    East Northport, NY
    155
    Wanted to add Borax but.....
    Walmart was out believe it or not. So, it is supposed to rain here tomorrow - will aeration from the rain really raise PH?
    Thanks!
    TF-100 Test Kit
    Aquabot Bravo
    38,242
    Re: Wanted to add Borax but.....
    Maybe ... I bet you know how to find of what it did to your water
    Why do you want to add borax? To raise the pH or add borates?
    I just merged 3 of your threads related to water chemistry.
    Aug 2014
    East Northport, NY
    155
    Yep to raise PH. After closer inspection those pucks are stabilizing pucks - after the rain subsides and I backwash I will add in a sock and run pump for 24 hrs. How many pucks will bring the CYA up?
    TF-100 Test Kit
    Aquabot Bravo
    38,242
    You should not put the trichlor tablets in a sock ... that advice is for pure stabilizer.
    You can use the Effects of adding Chemicals section of PoolMath to calculate what they will do in your pool.
    Aug 2014
    East Northport, NY
    155
    Ok well these blue pucks are intended for stabilization. But I think I need to wait until the rain passes and see what the numbers look like. I struggle with Pool Math actually
    TF-100 Test Kit
    Aquabot Bravo
    38,242
    Did you ever answer this?
    Quote Originally Posted by woodyp View Post
    What are the ingredients. All trichlor pucks have stabilizer in them. I am going to guess the blue ones have extra junk added, like maybe copper.
    Aug 2014
    East Northport, NY
    155
    the label doesn't give the ingredients. Probably because it was made in china. Here is a pic.
    TF-100 Test Kit
    Aquabot Bravo
    38,242
    I can not find any reliable information about what that is ... so, I would avoid it.
    Aug 2014
    East Northport, NY
    155
    Thanks. I just bought a 16 mil solar cover from in the swim so I am going to buy some stabilizer and other stuff from them since they gave a decent coupon. Appreciate the help.
    TF-100 Test Kit
    Aquabot Bravo
    Aug 2014
    East Northport, NY
    155
    So the stabilizer came in and it says I should broadcast it over the pool. Didn't I read that its best to use a sock in front of the return after backwashing? I just want to do this right and get the level up.
    TF-100 Test Kit
    Aquabot Bravo
    38,242
    Put it in a sock and place the sock in the skimmer (or hang in front of a return jet ... make sure it does not lay against the side of the pool).
  20. Back To Top    #20
    Aug 2014
    East Northport, NY
    155
    And run pump continuously correct?
    Yep I see it on pool school. Will add and run. So after 24 hrs should I test again?
    TF-100 Test Kit
    Aquabot Bravo
